Doors Sagging?
Old May 7, 2003 | 11:44 AM
PhucNguyen57's Avatar
Default Doors Sagging?
I think my passenger side door is drooping/sagging some. ANyone else have this problem? Should I just replace the hinges?
Old May 7, 2003 | 11:49 AM
Crazy Cooter's Avatar
Default Re: Doors Sagging? (PhucNguyen57)
Watch it while somebody picks up on the door while open. If it has play, replace it.
Old May 7, 2003 | 11:55 AM
civicmandx94's Avatar
I had this problem in my drivers side door. Just replace the hinge and it will solve the problem.
Old May 7, 2003 | 12:11 PM
J.P. 4rm The dPk*'s Avatar
Sometimes when you jack up the car from one side and leave it at a wierd angle over time the chassis starts to twist and the door sometimes has a harder time closing. I have the same problem it seems like the door tends to scrap before it goes it actually locks.
Old May 7, 2003 | 12:35 PM
Default Re: Doors Sagging? (Spooner)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spooner &raquo;</TD></TR><TR><TD CLASS="quote">Sometimes when you jack up the car from one side and leave it at a wierd angle over time the chassis starts to twist and the door sometimes has a harder time closing. I have the same problem it seems like the door tends to scrap before it goes it actually locks.</TD></TR></TABLE> mine scrapes the front fender, and everyonce in a shile catches it. It looks really bad. I saw this happen on a CRX that my brother owned, but it looked like his door hinges were different. Good to konw I can fix this easily. Thanks for the info everyone.
Caveman74's Avatar
You can jack up your door with a floor jack. I did it to my drivers side and it fixed it!
Old May 7, 2003 | 01:09 PM
Default Re: (Caveman74)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Caveman74 &raquo;</TD></TR><TR><TD CLASS="quote">You can jack up your door with a floor jack. I did it to my drivers side and it fixed it!</TD></TR></TABLE>
COOL, that will be a good quick fix until I have some time to fix it the right way.
Swiftstar
Sep 29, 2008 08:19 PM
rubber
Honda Civic (2006 - 2015)
Sep 21, 2007 09:34 PM
TRN
Oct 20, 2003 04:53 AM
01PYTypeR#1140
Apr 29, 2002 03:36 PM
