B20-91 civic DX hatch
what is it exactly what i need to do this i want to do a CRV/VTEC what are the things im gonna need? what ECU, axles, wirring harness. and also i want to bolt up a B16A2 tranny to the B20 will it work in the 91? do i have to convert it to rod shift or can i keep the cable shift?
--sigh---
1. motor mounts, Hasport is best
2. motor bracket from a 90-93 b18
3. 91-93 integra intermediate shaft and axles
4. flywheel/clutch for a cable tranny
5. cable b series tranny, LS, b16 or GSR (92-93)
6. 91-93 integra shift linkage
wiring can differ, you can make it OBD0 or OBDI. OBD0 would be better unless you want to pass smog. OBD0 would require a pr3 ECU, b16a1 wiring harness, b20 wiring harness. and some custom plug work, OBD I would require a p28 ECU, and a wiring adapter, and aslo some custom wiring
jedi_first_degree
Aug 21, 2005 05:30 PM
EFb18b
May 14, 2005 08:32 PM
