H22a Swap Shifter Cable Q's
Old May 7, 2003 | 08:13 AM
orangina's Avatar
Default H22a Swap Shifter Cable Q's
Did a search and still came up with confusion
Just to want to make sure/clear things up:
I'm about to use shifter cables and shifter base from a 2000 prelude - will this setup be ok on a 92 Civic Hatch using HCP mounts?
PS: for all you prelude guys - just saw on summitracing.com - they have STR Fuel Rails for Preludes on clearence for like $77
Old May 7, 2003 | 08:57 AM
Jonathan_ED3's Avatar
Default Re: H22a Swap Shifter Cable Q's (orangina)
Yeah it should work.
As far as I know the only difference is that the shifter base is made out of plastic, and will usually run you a little more than the older metal bases.
Old May 7, 2003 | 09:03 AM
junglerunna's Avatar
Default Re: H22a Swap Shifter Cable Q's (hot_EH)
Got pic from another thread.
Is this the shifter base you are using?
Old May 7, 2003 | 10:30 AM
Default Re: H22a Swap Shifter Cable Q's (junglerunna02)
Yeah that's what the 96+ bases look like.
Old May 7, 2003 | 10:31 AM
orangina's Avatar
cant see the pic right now - think maybe cuz some things are firewalled at my work? hmmm ill let u know when im @ my home computer
just to describe - its all plastic, off white color - really bulky looking compared to the older prelude units.
the cables should be no problem right?
Old May 7, 2003 | 10:40 AM
Yeah that's it.
The only problem you might have is that it might not fit under the stock console if you've got an EG.
It fits easier under EK's because they've got a higher console.
Old May 10, 2003 | 09:55 AM
blackedoutcivic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hot_EH &raquo;</TD></TR><TR><TD CLASS="quote">
It fits easier under EK's because they've got a higher console. </TD></TR></TABLE>
yup thats the shifter assembly i have.. fits perfect on my ek..
91H22REX
Jun 29, 2010 11:38 AM
daboi8
Apr 1, 2008 07:40 PM
ilovemydc5
Jan 20, 2007 01:03 PM
Freeltec
Apr 19, 2006 08:15 PM
