Why do Hondas grind in third gear?
Old May 7, 2003 | 07:15 AM
ITR1071's Avatar
Default Why do Hondas grind in third gear?
Most everyone I know has their third gear grinding first of all gears. Why?
Old May 7, 2003 | 08:12 AM
evolve's Avatar
Default Re: Why do Hondas grind in third gear? (KillaB18C5)
Third gear is almost always the first to go out, on all cars.
From my experience, this order; third, first, then second.
Old May 7, 2003 | 08:16 AM
Sleeper's Avatar
Because........
You can outshift the tranny with the stock shifter.
Pushing is easier than pulling.
No means no!
If it won't go in, don't force it, and your gears won't grind.
Old May 7, 2003 | 09:12 AM
Mikeman191's Avatar
2nd gear has double synchros... third only has one...
-mike
Old May 7, 2003 | 10:56 AM
AWD: Jeff's Avatar
Default Re: Why do Hondas grind in third gear? (Mikeman191)
happen to my third gear synchro, then my tranny went after that
Old May 7, 2003 | 11:32 AM
Katman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KillaB18C5 &raquo;</TD></TR><TR><TD CLASS="quote">Most everyone I know has their third gear grinding first of all gears. Why?</TD></TR></TABLE>
uh, cuz the syncros wear out.
This happens a lot w/Honda cable series trannies for some reason.
Old May 7, 2003 | 11:33 AM
Willard's Avatar
1st and 2nd have dual cone syncros 3rd has single.
Flush the fluid often and don't treat it like a T-5 (Mustang) tranny.
Old May 7, 2003 | 02:03 PM
Malgerus's Avatar
Default Re: Why do Hondas grind in third gear? (Willard)
My fourth gear synchro is the only one that grinds, for me.
Old May 7, 2003 | 02:32 PM
MikeSarr_GSR's Avatar
Default Re: Why do Hondas grind in third gear? (Mr. S)
yea, if you change the hub and synchro ring it will not be there...
you actually need to learn how to shift so that it wont grind.
if you wait a beat at the top of 2nd, you wont grind third. if it
still does, changing the hub and ring will become eminent soon.
been there.
Old May 7, 2003 | 04:18 PM
Ottoman's Avatar
looks like i've run across the same problem i guess..
didn't see this thread tho till now
https://honda-tech.com/zerothread?id=498966
Old May 7, 2003 | 05:02 PM
joyride's Avatar
i have the same problem too. oh well atleast im not the only one..
btw, do u guys have a short shifter or stock one?
Old May 7, 2003 | 05:58 PM
Al Bundy's Avatar
Third gear is the VTEC gear, thats why.
Old May 7, 2003 | 06:48 PM
bigblockEG's Avatar
VTEC Gear? What is a Vtec Gear? Powershifting 2nd is a straight pull down, third is over then up, leaving more room for missed shifts/grinds...
Old May 7, 2003 | 07:25 PM
Behan's Avatar
Default Re: (bigblockEG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bigblockEG &raquo;</TD></TR><TR><TD CLASS="quote">VTEC Gear? What is a Vtec Gear? </TD></TR></TABLE>
you've never experienced third gear vtec, you're missing out yo.
Old May 7, 2003 | 07:43 PM
romeo619romeo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bigblockEG &raquo;</TD></TR><TR><TD CLASS="quote"> third is over then up, leaving more room for missed shifts/grinds...</TD></TR></TABLE>
i power shift to third.. actually i power shift to 2nd all the way to 4th ..i never miss or grind.. pratice practice....
Old May 7, 2003 | 08:11 PM
Al Bundy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bigblockEG &raquo;</TD></TR><TR><TD CLASS="quote">VTEC Gear? What is a Vtec Gear? Powershifting 2nd is a straight pull down, third is over then up, leaving more room for missed shifts/grinds...</TD></TR></TABLE>
I was just playin around
Old May 7, 2003 | 09:00 PM
Default Re: (Al Bundy)
"I never miss" ... bawhaha ... I love the humility.
Wazup
Oct 25, 2007 02:47 PM
shawn_crx
Jun 29, 2005 11:18 AM
Jake
13
Mar 11, 2004 11:33 AM
sutats
Nov 4, 2001 06:27 AM
