why did it stall??
Old May 7, 2003 | 06:36 AM
GS-Rcivic's Avatar
Default why did it stall??
Ok, here is my question. Im runing a 94 b18c1 in my hatch with the NOS plate kit, 75 shot. Have a 255 pump, fuel rail, regulator (45 psi ), stock injectors, msd sci, coil, cap, wires. I was rolling yesterday and in 3rd gear going about 45 i hit the throttle and nitrous came on and stayed on through 3rd gear. When i shifted to 4th and hit the brakes, i noticed the car has stalled so the brake pedal was hard to press, so i restarted the car and everything was fine after that. Im also blowing black smoke everythime i get on it, even before nitrous and runing a testpipe. I dont know what the problem was but it got me worried. Any help will be apreciated. thanks.
also my engine is loosing the oil somehow. its not leaking anywhere but i used 3 quarts in 800 miles. Someone said it could be from runing too rich or a blocked pcv valve. ???
Old May 7, 2003 | 07:16 AM
untitled's Avatar
Default Re: why did it stall?? (GS-Rcivic)
i think it could have stalled from being too rich nd i also think the black smoke is from it being too rich. as for the oil.....i dont know. does it give a puff of white smoke on start-up? that could be an indication of blown valve stem seals. just throwing some things out there for ya.
Old May 7, 2003 | 07:26 AM
GS-Rcivic's Avatar
Default Re: why did it stall?? (88crx91integra)
no there is no white smoke, just black. Also i tried the nitrous on 4th gear and it kinda hasitated so i think im running too rich. What do you guys think should the fuel pressure be?
Old May 9, 2003 | 07:48 PM
GS-Rcivic's Avatar
man these posts go down fast. Anyone else, please?
rriicckk787
Apr 30, 2005 08:40 AM
Wide Open Throttle
Nov 2, 2003 05:07 PM
Brightazzsi
Sep 15, 2002 07:18 PM
