Are jdm ITR injectors specs different?
Old May 7, 2003 | 06:32 AM
paulITR's Avatar
Default Are jdm ITR injectors specs different?
I found that Euro and US Itr injectors have part #06164-P2J-000 and jdm' have # 06164-P72-010.
I ask because with my setup (look sign) at 56 psi fuel pressure i'm running on the lean side and stock injectors seem to be maxed out.
Can anyone tell if jdm injectors specs are higher?
Old May 7, 2003 | 08:53 AM
splitime's Avatar
Default Re: Are jdm ITR injectors specs different? (paulITR)
I've heard rumors that the jdm ITRs are 290 vs the 240 usdm models. Nothing was proven though, really just a rumor. I couldnt ever find a real answer on it.
Old May 7, 2003 | 08:56 AM
DutchITR1689's Avatar
https://honda-tech.com/zerothread?id=441513
Old May 7, 2003 | 10:24 AM
paulITR's Avatar
Default Re: Are jdm ITR injectors specs different? (DutchITR1689)
Did someone test jdm injectors?
Old May 7, 2003 | 10:39 AM
Maybe Miraiz knows more by now......
Old May 7, 2003 | 10:59 AM
paulITR's Avatar
Come on MiraiZ,
let us know.
Old May 7, 2003 | 11:08 AM
splitime's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DutchITR1689 &raquo;</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread?id=441513
Looks like he concluded they are 240cc.
Old May 7, 2003 | 11:26 AM
Default Re: Are jdm ITR injectors specs different? (splitime)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by splitime &raquo;</TD></TR><TR><TD CLASS="quote">
Looks like he concluded they are 240cc.</TD></TR></TABLE>Yeah, I know, but I want to know the difference.....why the part number is different etc.
Old May 7, 2003 | 12:38 PM
MiraiZ's Avatar
They are 240ccs..
Old Nov 12, 2010 | 07:57 AM
D0kt3r's Avatar
I own a JDM Type R B16B engine from a 2000 Honda civic Type Rx
I notice this post is very old, since 2003, but I would like to know the enjectors size of my B16B.
When I did the swap, I notice the plugs from my JDM B16A injectors where diferent from the EK9 injectors, and I just wanted to use my B16A 240cc injectors, till some one local told me, that B16B injectors are 290cc and are so programmed on the OBD2B ecu.
Reading this post, it sounds like the product number different only because of the plastic clip plugs.
I have run this engine with both OBD2B and OBD1 ecu, and for me, there is no difference while driving.
psegs80
Jun 19, 2007 08:50 AM
Pikachu
Mar 31, 2005 04:07 PM
wushubrian
Mar 14, 2005 12:37 AM
jonas
Jan 1, 2004 04:36 PM
ptsaurus
Dec 2, 2003 08:33 PM
