B16 probs, need advice !
Old May 7, 2003 | 06:14 AM
Danbu$'s Avatar
Default B16 probs, need advice !
Ok, i have a 91 civic dx, with a b16 i just recently dropped in. its running fairly well.
the only code im throwing is 4, which seems to be the Crank Postion Sensor. its idleing at 2 grand, and its running a little rich.
now i have swiched the 2 wires on the distrubutor and it made it run like ****, so i switched them back.
anybody have anhy ideas on what i might do ?
its running fairly smooth, minus the fact its idleing at 2k, but it hits vtec.
oh and there is also a bog when it hit WOT from 2500 to around 4000 rpm
any ideas ?
any help wouild be apprecitated
thanks
Dan,
Old May 7, 2003 | 06:20 AM
slowpokesi's Avatar
Default Re: B16 probs, need advice ! (Danbu$)
when i had a code 4 i got a new distributor and it solved the problem,
soo check your wiring again, check it on the ecu side, and if worse comes to worse find a new distributor.
Old May 7, 2003 | 06:40 AM
Danbu$'s Avatar
did your car idle high and bog whan you hade the code ?
just wondering.
Old May 7, 2003 | 06:54 AM
slowpokesi's Avatar
car ran like ****, and wouldnt rev past 3 k
Old May 7, 2003 | 07:50 AM
raene's Avatar
If the computer is telling you to replace the distributor, try replacing the distributor.
Just a thought.
Old May 7, 2003 | 10:09 AM
RCautoworks's Avatar
Did you do the wiring yourself ? If so did you shield the wire by the dizzy ?
Old May 7, 2003 | 10:50 AM
Danbu$'s Avatar
Default Re: B16 probs, need advice ! (90blackcrx)
no the computer doesn't tell me to replace the distributor, it simply gives me a code 4 which is Crank Position Sensor, which is in the distributor. therefore i was wondering if i replaced it, if it would fix my problem.
Old May 7, 2003 | 11:17 AM
raene's Avatar
It's telling you the crank position sensor is not working, which indicates a faulty distributor. Unless the wiring is done wrong, yes, try a new distributor If you're curious if it's a problem before you replace, go to a junkyard and ask to test an LS distributor.... someone please tell me the year again that works. It won't bolt up quite right but the electronics should be correct.
Old May 7, 2003 | 12:07 PM
Danbu$'s Avatar
Default Re: B16 probs, need advice ! (raene)
humm i guess i'll start looking for a newer used b16 distruibtor
thanks for the help
Old May 7, 2003 | 01:32 PM
Malgerus's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Danbu$ &raquo;</TD></TR><TR><TD CLASS="quote">humm i guess i'll start looking for a newer used b16 distruibtor
thanks for the help </TD></TR></TABLE>
Do you mean like a Del Sol VTEC one? Won't work... it's OBD-I. I've heard you can swap the guts from an LS distributor into a B16 distributor casing. Anyways, 90-91 is the year you want.
Old May 7, 2003 | 01:59 PM
Since you never answered me the first time, I'll ask again, did you do the wiring yourself ?
Old May 7, 2003 | 02:56 PM
Danbu$'s Avatar
No, i diddnt do the wiring myself, i had a friend do it, he's very good and i trust him completly, we have been over the wiring time and time again
he said he thinks its the distributor cause its throwing CPS code # 4
so i think thats what im going to have to do
Old May 7, 2003 | 03:05 PM
Well when you did the wiring, did you make sure you shielded the wire properly.
EFjoe91
Apr 3, 2016 04:36 AM
extensioncordy
10
Oct 30, 2006 07:21 AM
spettinger
Sep 28, 2004 10:19 AM
608 Gangsta
Sep 24, 2004 11:19 AM
WhiteDSM520
May 6, 2003 11:06 PM
