B18C5 bottom end with B16A head
Old May 6, 2003 | 11:53 PM
Mar_DC2's Avatar
Default B18C5 bottom end with B16A head
is this a good idea? anyone have any idea's of what the compression ratio might be with this set up and JDM ITR pistons? im debating between this or sleeving the bottom end and boring it out to 2.0L.
Old May 7, 2003 | 12:05 AM
NA gs-R 05 C
Guest
Posts: n/a
Default Re: B18C5 bottom end with B16A head (Btown_99Si)
do you have a type r motor or sumthin or jus the block, cuz a type r head is pretty much a b16 head. not only that, type r head comes wit the best b-series lost motion assemblies and a better valvetrain.
Old May 7, 2003 | 12:21 AM
Mar_DC2's Avatar
Default Re: B18C5 bottom end with B16A head (NA gs-R 05 C)
i wish i had a type-r motor. i have a B16A, but i'll be rebuilding the head over the summer with skunk 2 valves, valve springs, retainer's, and stage 2 cams. thats why i want the B18C5 bottom end. i forgot to mention that if i get the C5 bottom end ill be using JDM ITR piston's that are .25mm over.
Old May 7, 2003 | 12:22 AM
Jackson's Avatar
The compression ratio will be the same as the itr. You just wont have the better valves and valvetrain as mentioned.
Old May 7, 2003 | 12:29 AM
Mar_DC2's Avatar
Default Re: B18C5 bottom end with B16A head (Jackson)
sweet, thats all i needed. thanks.
Old May 7, 2003 | 12:47 AM
MikeMAN's Avatar
ITR = souped up b16 head i believe they are the same casting
mike
Old May 7, 2003 | 06:09 AM
MEANB18's Avatar
Default Re: B18C5 bottom end with B16A head (MikeMAN)
Nothing wrong with it at all, I've been running the B16 head on my B18c5 block for a while, and it's been able to pull on ITRs on the highway. (My engine is in an eg, so I weigh a ton less) but still, like has been said previously, it's the exact same head, just a little more port work done I believe, and the lost motion assemblies are better.
Old May 7, 2003 | 03:57 PM
riceboyEFsi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Btown_99Si &raquo;</TD></TR><TR><TD CLASS="quote">is this a good idea? anyone have any idea's of what the compression ratio might be with this set up and JDM ITR pistons? im debating between this or sleeving the bottom end and boring it out to 2.0L.</TD></TR></TABLE>
i just blew up this setup word to the wise dont mill the head to much if your running skunk stage 2's , otherwise i was very happy . If u already have an itr shortblock use it otherwise save yourself some $$$ and buy yourself a gsr block. I also have a legit b18c5 block 4 sale it needs to be resleeved . Ill take 200. 4 it pm me if your interested
Old May 7, 2003 | 10:23 PM
Mar_DC2's Avatar
Default Re: B18C5 bottom end with B16A head (riceboyEFsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by riceboyEFsi &raquo;</TD></TR><TR><TD CLASS="quote">
I also have a legit b18c5 block 4 sale it needs to be resleeved . Ill take 200. 4 it pm me if your interested</TD></TR></TABLE>
you have mail.
Old May 8, 2003 | 06:10 AM
ACRXGuy's Avatar
I am pulling 186 HP with the basic bolt on's with the b16a head and the ITR block.
I have a ITR intake cam, GSR exhaust cam, ITR Valve springs and retainers, skunk2 cam gears, skunk2 intake manifold and a FPR. The head was milled 10, not sure what measurement you use, but you get the Idea.
Great Set up and less money.
Sal
Old May 9, 2003 | 11:38 AM
2slo4me's Avatar
hey im very interested in te b18c5 block uhave for sale email me spider69911@yahoo.com im in queens
Eddygee53
16
Jul 9, 2019 12:19 PM
domsb16
16
Sep 30, 2007 10:24 PM
psegs80
14
Mar 24, 2006 07:49 PM
CrazyKoreanCrx
Jan 29, 2003 12:52 PM
