a motor/turbo question
ok i have a qustion and i did some research.
i want to go turbo for my crx. i'm either choosin either an ls or a gsr, but then my bro is tellin me a zc is better to go for turbo.
so my main question what the best engine for tubro for a crx? i wanna hit's 13's then high 12.
thanks
thanks
ZC's have tiny rods and will probably not withstand enough boost to get into the 12's. You will have to build the ZC. A stock or mildly built B-series + turbo will be more reliable and should get you the times you want.
i am going to be running a dohc Zc at 8psi. I should be able to hit mid 13's.
To get into the 12's tho, i would suggest doing something like a turbo'd crv vtech (b20). You could easily hit mid to low 12's with a big enough turbo, and built internals.
cool but why stop at 12 or 13 in1/4 why not 10 or 11 i have a b16a1 built in all aspects for forced boost through the t3/t4 turbo and 2 50 shot nos and the rest is up to the driver you never know mabey you can beet me if you a good enough driver
so id say b16a1 with a booster chair
AbaZ
Sep 16, 2002 07:36 PM
