problems with grease
Old May 6, 2003 | 10:30 PM
beeboyee's Avatar
Default problems with grease
found grease all over the inside of the front rims
what could it be? i dont have a jack at the moment
just wondering if it could be cv boot or maybee axle problems?
TIA!
Old May 6, 2003 | 10:37 PM
eg_nezay's Avatar
Default Re: problems with grease (beeboyee)
Its your boot y0, replace it= $10 or rebuild your axle=$45.
Also check your balljoint.
Old May 7, 2003 | 12:07 AM
beeboyee's Avatar
Default Re: problems with grease (eg_nezay)
good crapola!
how much are some axles?
Old May 7, 2003 | 05:36 AM
Stew Pidasso's Avatar
Remanufactured ones go for around 60-80 bucks apiece. If you're running more power though I would suggest some new OEMs or something from DSS.
Old May 7, 2003 | 08:44 AM
you69's Avatar
fix this quick! if you are doing just the boot. if you hear some weird noise from it then its to late you need a CV joint
Old May 7, 2003 | 11:21 PM
beeboyee's Avatar
Default Re: problems with grease (you69)
i figured i might es'well change the whole axle
EJ8 GSR-T
May 17, 2007 07:19 PM
sohcef9
15
Oct 2, 2005 06:39 AM
kevinmac99
Sep 23, 2004 10:31 PM
Simple
Feb 1, 2004 02:46 PM
eur0
19
Nov 16, 2002 08:54 PM
