all-wheel-drive type r
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vtec-Jesus »</TD></TR><TR><TD CLASS="quote">just got the new hondatuning issue and was reading about the awd type-r, just curious what other people thought about this project.</TD></TR></TABLE>
you mean blake's idea/project?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GettaluvR »</TD></TR><TR><TD CLASS="quote">why not just get a WRX
with all the money spend at the R to make it AWD might as well buy a WRX STi</TD></TR></TABLE>
what if it's a race car being built for ppihc?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ArmyGreen EG »</TD></TR><TR><TD CLASS="quote">i was under the impression that they made them in very small quanities in japan but they had alot of problems,i have heard of blakes idea also.</TD></TR></TABLE>
this is correct, Dseries motor wasn't it?
there is awd type r... wrx that is http://rallypleiades.infoseek....0.htm
this idea sounds good to me, i wonder if they'll just use parts from other awd car and mate it to itr motor.. i would settle for rwd integra if someone would come up with a kit.
RWD.. tube frame, rear diff turned upside down, custom tranny.. not hard, there's a number of RWD CRX/Integra GT race cars.. all are tube frames though.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dawhiteboy »</TD></TR><TR><TD CLASS="quote">
this is correct, Dseries motor wasn't it?</TD></TR></TABLE>
I Think it may have been a ZC. I am not to sure tho.
it also says that they hope to map the possiblities of converting honda/acuras to AWD to create a new feild for h/a tuning enthusiasts. they want the awd type-r to hang with the mitsubishi evo 8 and the WRX STi
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dawhiteboy »</TD></TR><TR><TD CLASS="quote">RWD.. tube frame, rear diff turned upside down, custom tranny.. not hard, there's a number of RWD CRX/Integra GT race cars.. all are tube frames though.</TD></TR></TABLE>
what involved in making a tube frame for this application? is it somewhat of a rollcage or just extra reenforcements?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Big Teggie »</TD></TR><TR><TD CLASS="quote">
I Think it may have been a ZC. I am not to sure tho. </TD></TR></TABLE>
That is correct
That is correct
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lip »</TD></TR><TR><TD CLASS="quote">canadian teg also came awd as well.</TD></TR></TABLE>
Which model? I have never seen an AWD teg here
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by canuck-mx6 »</TD></TR><TR><TD CLASS="quote">
Which model? I have never seen an AWD teg here</TD></TR></TABLE>
the 2000 Type-R's came AWD, I have one
i thought it was available. something i heard years ago... xi model or something like that? please correct me if i'm wrong...i'll make note of it
They had a low horsepower version in Japan powered by the ZC, but people who tried building them said they couldnt handle that much power. This is probably due to the weak differential which wasnt intended for high torque applications. For those of you who know Blake and his determination, all I got to say to the rest is Watch out and stay tuned!LOLOL!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vtec-Jesus »</TD></TR><TR><TD CLASS="quote">it also says that they hope to map the possiblities of converting honda/acuras to AWD to create a new feild for h/a tuning enthusiasts. they want the awd type-r to hang with the mitsubishi evo 8 and the WRX STi</TD></TR></TABLE>
That all sounds good and dandy, but not only are you missing extra HP from the equation, you'll need considerably more torque. FWD's have a relatively low driveline hp loss because of the fewer components than RWD or AWD.. Do you really think 130 ft-lbs of torque is going to be any good with a RWD setup..? I think not, let alone an AWD setup. IMHO, an AWD Integra (type R as it may be) will be severly underpowered (assuming relatively mild N/A setup). A boosted teg.. now thats another story
First of all, its not a Type R!!! Second, its a DB9 4WD officially called Honda Integra ZXI 4WD.
These pics should answer all your questions....and finally, putting a b18c in it isnt worth it, the weakass tranny would never survive..
Made for snow country...notice the SUV ride height
ZC Engine
ZC Engine
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fiebru1119 »</TD></TR><TR><TD CLASS="quote">
That all sounds good and dandy, but not only are you missing extra HP from the equation, you'll need considerably more torque. FWD's have a relatively low driveline hp loss because of the fewer components than RWD or AWD.. Do you really think 130 ft-lbs of torque is going to be any good with a RWD setup..? I think not, let alone an AWD setup. IMHO, an AWD Integra (type R as it may be) will be severly underpowered (assuming relatively mild N/A setup). A boosted teg.. now thats another story </TD></TR></TABLE>
Yes, RWD bseries setups do fine. AWD, dunno. AWD does have a LOT more driveline loss, RWD isn't that bad at all though.
edit: D16 motors also do fine with RWD setups in tubeframe CRXes..
of course, a tube frame crx is just a small trube frame with a fiberglass crx body
but the motor is still a D16.
damn that is some SUV action
no one seriously said Type-R's came in AWD however Blake and maybe others were talking about building an AWD type-r. His plans were for PPIHC competition.
The differential was ridiculously weak and could not even handle a low horsepower/low torque honda engine.
An AWD ITR for Pikes peak or any other racing application would not be able to use the parts that were used on the ZXI, they'd have to try something else.
