code 16 and lot of smoke and smell off gas from exhaust
all i did was changed the oil and when i started my car it ran like crap with a bunch of codes then i unpluged the ecu and pluged it back in and it ran alot better but still has a code 16 and it's smoking pretty bad. can someone please help me with this.
thanx
thanx
http://hybrid2.honda-perf.org/tech/codes.html
The code is for the fuel injection system. I don't know any more than that.
Edit: Because I can't read good.
Modified by CRX PAT at 7:46 AM 5/7/2003
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX PAT »</TD></TR><TR><TD CLASS="quote"> http://hybrid2.honda-perf.org/tech/codes.html
The code is for the ignition output signal. I don't know any more than that.</TD></TR></TABLE>
u read i wrong buddy
its Fuel Injector code
either one fo ur fuel injectors its fried or theres a mafunction on the harness of the FI.... and its making ur injector to stay open and flood the cylinder.. happened to me when the #1 inj cable was fractured.....
check your wireing for the mpfi if your not shure the new honda tuneing has the full mpfi conversion in it and it's the right wireing for shure.
88rexdxa6ed
May 6, 2003 09:58 PM
