How do you remove the distributor rotor?!
I'm installing my ignition in 100+ degree heat and I take the distributor cap off and need to get access to the coil, but the rotor is preventing me from taking the casing off. How do I take the rotor off? I looked at it for a little bit, but since it's so hot outside, I don't feel like sitting there and thinking lol. Please help, thanks.
*SIGH*
There's a screw that holds the rotor onto the shaft. if you turn the engine a little, it'll show up eventually.
yeah, it so frakin easy once you see the screw. it screws into the shaft of the rotor. You can use a 19mm wrench to turn the rotor over, or just take of the distr (3 bolts) and turn it yourself. HTH, -C
zairas
Oct 19, 2009 03:08 PM
beanwagon
Aug 3, 2009 02:57 PM
