Ok just got some new wheels for the lude will 16x8 rub with low pros/////// on stock ride height
Old May 6, 2003 | 01:09 PM
atlprelude01's Avatar
Default Ok just got some new wheels for the lude will 16x8 rub with low pros/////// on stock ride height
Ok does anyone know first hand or have an idea will 16x8 rub with low pros/// on fifth gen lude
Old May 6, 2003 | 01:13 PM
Boostless97Lude
Guest
Posts: n/a
Default Re: Ok just got some new wheels for the lude will 16x8 rub with low pros/////// on stock ride height
probably won't rub, but it'll look ghetto with some "low pros" on factory height
Old May 6, 2003 | 01:21 PM
aklucsarits's Avatar
New User
You need to give a lot more detail than that if you expect anyone to help you.
8" wide wheels will fit fine on 4th gen and 5th gen preludes - but only IF you have the correct wheel offset. So what kind of Prelude do you have? And what offset are your 16x8 wheels?
Andrew - who does not understand what "low pros/////// " is supposed mean
Old May 6, 2003 | 01:47 PM
OK sorry, High performance tires. I for whatever reason cant find the offset on them and fifth gen lude means 97-01 and my lude is a base
Old May 6, 2003 | 01:52 PM
16x8jj is all it says, why doesnt it say the offset wtf does jj mean
Old May 6, 2003 | 01:58 PM
New User
Default Re: (atlprelude01)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by atlprelude01 &raquo;</TD></TR><TR><TD CLASS="quote">16x8jj is all it says, why doesnt it say the offset wtf does jj mean</TD></TR></TABLE>
The wheel will have the offset cast in in somewhere on the backside of the wheel. It will say "+40" or "+35" or something like that.
So are you saying that you already have the wheels in question? Why not just test fit them front and rear? You don't need tires on them. Just mounting the wheel itself on the hub should give you a good idea of whether the offset is going to be OK or not.
Andrew
Old May 6, 2003 | 02:08 PM
OK these are some cheap 16 inch alloys from proline, although they look awesome and are made well. I swear theres no offset anywhere on here have had two previous sets of wheels and found it easily. Thanks andrew ill just try them (good jack is at my boys house the honda one sux ***)
Old May 6, 2003 | 02:19 PM
BoostedH23a1's Avatar
i need some 10 inch wide rims... to bad **** will fit uneless i do some mad custom ****.. that would be tight
Old May 6, 2003 | 03:08 PM
optikal_blitz's Avatar
not even wheel spacers? haha
superiorx120
Dec 1, 2010 02:10 AM
wtfitzphat
Aug 30, 2008 08:50 AM
MaWeiTao
Jun 15, 2005 05:43 AM
DanielLaruso
Sep 3, 2003 11:49 AM
accrd01
Aug 20, 2001 10:22 AM
