What radiator are you using?
I have a B18C1 in my EG hatch and was wondering if the stock radiator should be sufficient in New Mexico type weather? I have no A/C, power steering, but my radiator is custom mounted in the center. Should I upgrade to Fluidyne's radiator, or will I stay cool, in the hot summer with a stock DX radiator?
you can do alittle hacking in the lower mount poiints and fit a GSR or ITR or LS radiator in there, might be your best bet for the buck.
I run a GSR rad. in my 92 Hatch with a GSR swap... the used GSR rad. from http://www.importautosalvage.com was like $80 shipped.
I run a stock 130k mile VX radiator in my B16 EG. No problems at all. Also have a new fan switch, thermostat, and water pump. As long as your cooling system is in good shape a stock EG radiator will work fine.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spoon92 »</TD></TR><TR><TD CLASS="quote">I have a B18C1 in my EG hatch and was wondering if the stock radiator should be sufficient in New Mexico type weather? I have no A/C, power steering, but my radiator is custom mounted in the center. Should I upgrade to Fluidyne's radiator, or will I stay cool, in the hot summer with a stock DX radiator?</TD></TR></TABLE>
your stock radiator should be sufficient. I have a C&R radiator though, reason being that my stock radiator was leaking from the fins and end tanks so I just replaced it with something better. kinda of overkill though.
Some guys run the stock radiator which I guess is ok. But after going all out with my motor swap and painstakingly putting every detail together why not have the added protection of a dual core radiator.
I used a 00 Si radiator cost was 114.00 plus 10.00 in shipping had it the next day.
I spent way too much on my swap/car in general... so I bought a fluidyne and I like it a lot- my temps don't budge from normal no matter what the weather is like and no matter how hard I drive.
Either way a little extra protection (weather an oem upgrade or an aftermarket) is good for peace of mind.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxmatt »</TD></TR><TR><TD CLASS="quote">I run a stock 130k mile VX radiator in my B16 EG. No problems at all.</TD></TR></TABLE>
150K+ on my 92 VX with 99 B18C1 which has been in there for about 3 years now. Never has overheated, actually it hasn't went above the operating temp that the VX motor ran at.
91 CRX HF with a B16. I have the stock radiator, and have never gone past the half mark. Like someone said before, as long as your cooling system is working properly, it will be fine.
i would never run a stock radiator again...so un reliable...could bust ne time...prolly won't kinda like lowerin your car on stock shocks...my luck isn't very good so i don't wanna press it
anotherwhitehatch
Aug 3, 2007 09:01 PM
808State
Jan 24, 2007 08:10 PM
B_1_8_hatch
Aug 3, 2003 01:06 PM
