Mounting Hardware for OEM ITR lip
can someone post a diagram, or the part numbers for the OEM ITR front lip mounting hardware.... i just purchased the OEM lip from a fellow ht member, but he doesn't have the mounting screws because it's been a while since he used the lip (went jdm front)... thanx!
ok i went to honday and bought the screws and clips for where the lip attaches at each end....and i also bought the 10mil bolts that attach the lip from the bottom.... but they don't thread into anything..... do i also need clips for the bolts to screw into...? thanx....and a pic would be perfect if someone has one
someone could just go out and look at their r.....and see how their front lip is attached on the bottom...... and then tell me how.... is it a clip of some sort that the bolts thread into....cuz there is not thread in the bumper...
^thanx man..... so you can find these tinnerman clips at any hardware store i suppose? cuz i don't feel like getting bent over from honda again.....i purchased all the bolts and two end screws from honda today and it cost $15CDN.... and i didn't get the tinnerman clips...
you can go to the hardware store but they will likely only have standard. Plus they will not fit perfectly and you will have to buy another set of bolts/washers. I say to just f-it and by it from the dealer or go to a wrecker.
tdesi420
Aug 29, 2008 10:45 PM
