Are my TPS wires in the right order?
Old May 6, 2003 | 11:30 AM
FourthGenHatch's Avatar
Default Are my TPS wires in the right order?
I know you had to switch some of them when going to MPFI. I cleaned out my throttle body today and now my car surges and revs straight to as high as it can go. I figure it could be a TPS sensor issue. Anyone tell me what is the right order?
Old May 6, 2003 | 12:55 PM
drjondurst's Avatar
Default Re: Are my TPS wires in the right order? (FourthGenHatch)
Im pretty sure thats right. Did you ever take the TPS off the throttle body?
Old May 6, 2003 | 12:59 PM
Default Re: Are my TPS wires in the right order? (drjondurst)
I did take it off, mine came with screws that were easily removed (I guess the previous owner did that since I thought they were rivetted on). How can I fix this. I should be able to drive the car tomorrow after I put the header on so I a tired of waiting.
Old May 6, 2003 | 04:35 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
dude! your TPS is upside down ..The wiring looks right though...
I have a B16 and a D16 and on both of them the tps points down,not up as in your picture.
Modified by 88DXCRX at 7:58 PM 5/6/2003
Old May 6, 2003 | 05:02 PM
MONSTERZC's Avatar
Default Re: Are my TPS wires in the right order? (88DXCRX)
88dx is right your tps is upside down
Old May 6, 2003 | 05:26 PM
drjondurst's Avatar
Ha yea, it is upside down. When I was looking at it earlier I was trying to figure out what angle u took that pic from.
Also, whenever you remove your TPS, you've gotta re adjust it back on to where its at .5v idle and 4.5v WOT. I had mine misadjusted for a while and my car idled at 4K.
Old May 7, 2003 | 06:16 AM
Default Re: (drjondurst)
I thought it was upside down because I took off the throttle body because I wanted to clean it. I took out my Chiltons and was looking at the 88-91 Si throttle body because I thought they were the same and I noticed how theirs pointed down. So I took it off but inside it looks like it just matches up right like that. So if I move it downward 90* or whatever it should be better? I can deal with high idle for a while but 7200rpm high idle I cannot.
Also how do you adjust it to the right voltage, turn it slightly?
Old May 7, 2003 | 10:42 AM
zCivic's Avatar
Default Re: (FourthGenHatch)
turn the ignition on and turn the TPS til its correct at closed, then WOT....
Code 7
http://www.we-todd-did-racing....3D%3D 11-56
http://www.we-todd-did-racing....3D%3D 11-57
Old May 7, 2003 | 10:50 AM
Default Re: (zCivic)
I went and switched it today, I had to do it basically 180*, so i assume before it was stuck at WOT. I haven't ran it today cuz I'm sick of the open header sound but once I get my header I think it will be fine.
Em1Trevor
Oct 29, 2015 10:09 PM
valentine97
19
Jan 15, 2008 10:33 AM
nutball72
Nov 11, 2006 07:14 PM
Leviata-N
Oct 1, 2004 09:12 PM
Redsim
Jun 11, 2003 09:37 PM
