Kirk Roll Cage Clearance
I searched through a lot of the roll cage posts, but couldn't find much info on this, so do any of you guys know if the Kirk Roll cage will clear the ITR rear strut tower bar? Thanks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ »</TD></TR><TR><TD CLASS="quote"> If you have a cage, you likely wont need the strut tower bar</TD></TR></TABLE>
what he said. but to answer the question, no it wont (well might be able to get it to clear cause you can move it around a bit, but still).
the sp00m rear bar clears though. mugen should too. a number of others probably would clear as well.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lOng dOng Silver »</TD></TR><TR><TD CLASS="quote">
Kirk Roll Cage Clearance </TD></TR></TABLE>
Man .. I though roll cages were going cheep. I was a little excited.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowassR »</TD></TR><TR><TD CLASS="quote">
hahhhaa
</TD></TR></TABLE>hahhhaa
unless you need something to strap the cooler to.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecvoodoo »</TD></TR><TR><TD CLASS="quote">
unless you need something to strap the cooler to.</TD></TR></TABLE>
or the sub/amp box.
or the sub/amp box.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecvoodoo »</TD></TR><TR><TD CLASS="quote">or the gunrack
well I use the rear window struts for that.
</TD></TR></TABLE>well I use the rear window struts for that.
92 civic VX B18c
11
Oct 10, 2004 11:26 AM
