Miata rims: What bore size?
Old May 6, 2003 | 10:29 AM
Smokinsax's Avatar
The Boot
Default Miata rims: What bore size?
I picked up a set of Miata rims (kinda like Panasports) and need to bore out the center hub area but I dont know exactly what to bore it out to. I have seen that they are 53mm and need to go about 56mm to fit the civic hub, is this correct? Any DIY'ers, what did you use to do this?
Old May 6, 2003 | 10:47 AM
CVC9216's Avatar
Default Re: Miata rims: What bore size? (Smokinsax)
Could be wrong, but I think the miatas are 54.1 mm and civic is 56.1 mm. Very slight difference, you could probably just dremel it.
Old May 8, 2003 | 09:47 AM
Smokinsax's Avatar
The Boot
Default Re: Miata rims: What bore size? (CVC9216)
Attempted to use a dremel, and used a grinding bit. Its not going to work with that cause the aluminum just bonds with the bit and becomes smooth over it. Any other ideas other than a matchine shop?
Old May 8, 2003 | 10:13 AM
clm's Avatar
clm
I suppose you could probably get a drill press with a really big drill bit.
Old May 8, 2003 | 04:20 PM
squeaky's Avatar
Default Re: Miata rims: What bore size? (clm)
Goto Lowes and get a 57mm hole saw. Use a good hand drill cuz I burned out the motor in my 10 yr old electril drill (she had a lot of good yrs...) but I had a heavy duty drill as well. Start slow and don't let your drill get too hot. Not too much to it.
zsiya
Feb 20, 2013 08:07 AM
CW-ITR
Oct 21, 2009 01:44 PM
dc2much
Mar 15, 2008 08:29 AM
darkvibe
Apr 4, 2004 08:55 PM
rocket_R
Jul 29, 2002 07:00 PM
