Ignition fuse keeps blowing!!!!!
Old May 6, 2003 | 08:59 AM
MeanGreenEG9's Avatar
Default Ignition fuse keeps blowing!!!!!
last night my main relay fuse or battery fuse blew.. today I found out why.. its my ignition fuse... when it blows so does the main relay fuse... not sure why though...
i checked all wires and no broken circuits... everytime i put a new fuse into the igition fuse and then reconnect the ground battery cable.. boom! blows right away.. no hesitation.. any thoughts ideas??
Old May 6, 2003 | 09:13 AM
Stew Pidasso's Avatar
Default Re: Ignition fuse keeps blowing!!!!! (B16aEJ)
I would say there is a short somewhere. You just have to track it down. Are you sure your starter is grounded/wired properly??
Old May 6, 2003 | 10:17 AM
Default Re: Ignition fuse keeps blowing!!!!! (Stew Pidasso)
well if its the igntion fuse thats blowing.. wouldnt it have something to do with the actual ignition system? I've checked all the wires. i dont see any breaks... I even unplugged the distributor plug that connects to the wiring harness,.. still blows...
I've gone through about 10 fuses... this is getting expensive as well
dhealey
Honda CR-V & Element
11
Jun 5, 2024 06:31 PM
crix868
May 13, 2005 11:08 AM
tuan...
Aug 7, 2004 05:47 AM
ModlesSI
Feb 22, 2003 03:16 PM
