removing head?
Old Jul 5, 2001 | 11:56 AM
quikrpm'z's Avatar
Default removing head?
can u guys give me the proper steps to removing the head. Theres like ten bolts labeled "R", I take it those are the bolts holding the head on? Does the cam's have to be removed? IF any one can scan, or know of a site, that would help pls post a link. thx.
Old Jul 5, 2001 | 02:00 PM
johng's Avatar
Default Re: removing head? (quikrpm1)
Ummm.....what motor? You don't have to remove the cam on a D series. Not sure about B series motors. There is a head bolt removal sequence remember. If you don't have a Helms, go to the dealer and photocopy the pages you need.
Old Jul 5, 2001 | 04:27 PM
quikrpm'z's Avatar
Default Re: removing head? (johng)
sorry , 96 b18b. I already removed the cams, the header bolts wont budge i think I'm going to need an impact wrench.
Old Jul 5, 2001 | 05:02 PM
johng's Avatar
The "header" bolts should be pretty easy. The "head" bolts will be tough.
Old Jul 6, 2001 | 07:05 AM
bigTom's Avatar
i guess every situation is differant... getting the head bolts off mine was easy... but i had a lot of leverage... the header bolts were a bitch!!! i ended up stri[[ing one of the nuts and ended up cutting it off by hand... just be careful not to strip the header bolts if u cant get them off... u WILL regret it if u do
Old Jul 6, 2001 | 07:45 AM
johng's Avatar
Default Re: removing head? (4dr-gsr)
I guess so. My head bolts almost killed me. I thought they were going to break when I was removing them.
Old Jul 7, 2001 | 08:05 PM
quikrpm'z's Avatar
did u guys have the engine on an engine holder? Or just laying on a bench? MInes is on a bench, and that engine just turns.
Old Jul 7, 2001 | 08:07 PM
quikrpm'z's Avatar
shiet, i just reread that other post "header bolts", I meant the head, bolts are giving me trouble.
Old Jul 8, 2001 | 04:25 PM
ringgold's Avatar
I just removed the head on my d16y8 it was pretty straight forward no big problems just hope that I can bolt it all back up. I had a problem with the header bolts rounded 3 off. I had to put vice grips on them as tight as I could and strain my *** off to get them off. I finally did but like I said I hope I can bolt all this junk back up.
Old Jul 9, 2001 | 12:19 AM
GZR4DR's Avatar
Default Re: removing head? (ringgold)
dont use a long extension on the ratchet, the shorter the better, use good sockets (snap-on, matco), and a long breaker bar, and you should never strip a header bolt.
Old Jul 9, 2001 | 07:00 AM
92Si's Avatar
New User
Default Re: removing head? (GZR4DR)
Also, Use 6 point sockets.
Old Jul 9, 2001 | 08:48 AM
ringgold's Avatar
Default Re: removing head? (92Si)
I used a 6 point metric socket and no extension all 3 that rounded off were across the top row of bolts. Thats all right I was planning on getting some new ones. I guess that they kinda seized up on there from getting hot then cold alot.
Old Jul 9, 2001 | 09:43 AM
I2secRex's Avatar
New User
The Header bolts should be a sinch if you drip some Liquid Wrench or WD40 on there the night before and let it soak.
The head bolts aren't going to be TOO difficult... just use a nice size braker bar and get someone to hold the motor still while you crank at it (if it's out of the car). They're only torqued to about 60-70 lb/ft so it's not as hard as the crank pulley. Have no fear, you'll get them off.
Yes, in a B series motor the cams must come out.
-Kevin
journeyquest
Sep 29, 2011 05:23 PM
wantboost
Apr 30, 2011 05:28 PM
xiaogou
Apr 7, 2007 12:47 PM
lilpastrana
Oct 18, 2006 03:30 PM
standbackimapro
Dec 21, 2005 05:20 PM
