What is the most power potential powerplant?
Old May 5, 2003 | 09:00 PM
mYsTeR2's Avatar
Default What is the most power potential powerplant?
Like the title says I'm wondering which motor has the most power potential going the N/A route. I already searched and came up with nothing. Thanks in advance.
Old May 5, 2003 | 09:31 PM
msilbernagel's Avatar
Default Re: What is the most power potential powerplant? (mYsTeR2)
Bit vague -- what if they answered with "454cid Chevy"?
Besides context of 'the car' it's going into, there is also your investment.
Time, which means educating yourself to learn "what you want" (street, strip, WOT, low-end, rally, etc). Time to lean how to do what needs to be done. Time to locate all the parts...
Budget, be real.
Circumstance -- maybe you're lucky and have some experienced folks nearby, who will even work for !
Bisi does miracles with NA, others with B20 or B18 ls/vtecs, some with B18Cs...
They can all hit low to mid 200's with enough attention, but you're into serious budget by then.
Mark
Old May 6, 2003 | 05:30 PM
mYsTeR2's Avatar
Default Re: What is the most power potential powerplant? (msilbernagel)
This would be going into an ek hatchback and im talking about honda motors. IT would be for street/strip.
Old May 6, 2003 | 05:32 PM
dfoxengr's Avatar
umm. any Bseries 1.8L or more. because youd want to bore, and stroke it anyways... that way you can have the max of both.
Old May 6, 2003 | 05:38 PM
Default Re: What is the most power potential powerplant? (hybridvteceg)
Isn't Bisi running H22? Dude's getting 10's N/A...
Old May 6, 2003 | 05:51 PM
dfoxengr's Avatar
thats cool. how much does his car weigh..
y does it matter, hell go with a non-vtec sohc motor. seen 10.90s with that setup...of course thats in a 1600 or so lb car...and i think 18:1 compression
dfoxengr's Avatar
basically you can make anything fast that you want to, all about time, money, and imagination...
Old May 6, 2003 | 10:36 PM
MikeSarr_GSR's Avatar
Here is a suggestion:
GSR head, ported/flowed for 12mm cams mild resurfacing for squareness
Stock HG with ARP head studs, main cap bolts, rod bolts
Toda spec Bs, ITR LMAs, toda valvesprings, portflow retainers, cam gears
PE/Toda timing belt
ITR block w/CTR pistons
Prodrive or Toda billet B18 oil pump gear
mugen thermostat with fluidyne radiator and single fan
64mm TB/Skunk2 Intake manifold with hondata thermal break gaskets
SMSP or Hytech header w/2.5" exhaust
Comptech Ice Box
97 prelude injectors and fuel pump, B&M FPR
hondata s200 tuning, OBD1 P72ecu, full gauges
USDM ITR tranny with JDM final gear
Action Kevlar clutch/10lb flywheel
This combination could net as much as
230/150 SAE corrected at the wheels fully tuned...
Can you say 9500 RPM? such a motor with the right
driver should see 11s in a hatchie. With slicks,
dare I say 10s...
Just depends on how fast your wallet is.
Old May 6, 2003 | 11:21 PM
ExospeedAMcrx's Avatar
Default Re: What is the most power potential powerplant? (MikeSarr_GSR)
Id lwish that setup can get into the 10s' but.. i highly doubt it. Most racers in the 10's have way more aggressive setups than that. The setup you mentioned is common and most arent even 11's with that combination.
To get into the 10's start looking at over 240whp for high 10 sec runs on a light *** CRX with perfect suspension setup.
Old May 6, 2003 | 11:32 PM
AllmotorJunkie's Avatar
Grab some imprt magazines and read up on other peoples setup. That should give you an idea of how different setup nets different whp.
Old May 7, 2003 | 12:02 AM
aeolus's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MikeSarr_GSR &raquo;</TD></TR><TR><TD CLASS="quote">Here is a suggestion:
PE/Toda timing belt
Comptech Ice Box
dare I say 10s...
Just depends on how fast your wallet is.</TD></TR></TABLE>
i say maybe 11's if the car is gutted.And i mean GUTTED!
Old May 7, 2003 | 02:20 AM
Default Re: What is the most power potential powerplant? (aeolus)
11s is a beautiful thing none the less, I'll take 12 personally with somewhat of an interior. Since SgT has ran high 11s in his ITR with a similar build... it can be had in a hatch. On something like this you are talking 270/180 flywheel hp/tq from 1.8L... can you say 150ps/liter? thats insane.
Modified by MikeSarr_GSR at 6:31 AM 5/7/2003
Old May 7, 2003 | 02:51 AM
sgT's Avatar
sgT
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MikeSarr_GSR &raquo;</TD></TR><TR><TD CLASS="quote">11s is a beautiful thing none the less, I'll take 12 personally with somewhat of an interior. Since SgT has ran high 11s in his ITR with a similar build... it can be had in a hatch. On something like this you are talking 270/180 flywheel hp/tq from 1.8L... can you say 150ps/liter? thats insane.
Modified by MikeSarr_GSR at 6:31 AM 5/7/2003</TD></TR></TABLE>
Well, I actually ran mid 12s inthe integra, but i didnt have 1/4 of the list you have there.
Old May 7, 2003 | 10:12 AM
Default Re: What is the most power potential powerplant? (sgT)
sh*t man thats fast enough for me. im just saying that fast times can be had with a larger car. you must have felt your ears burning... I was incorrect.
this is the page I remember looking at:
http://ghettoracer.com/~sgt/itr1.html
cheers
LIKEABO55
Honda CR-V & Element
Jan 16, 2013 07:30 AM
wesley_925
Mar 22, 2008 03:04 AM
Hella_Fresh
Dec 2, 2004 11:26 PM
SiRkid
Feb 13, 2003 01:07 PM
turbochris
Jun 29, 2001 04:37 PM
