Throttle body selection for LS turbo
Old May 5, 2003 | 03:27 PM
Mr.Saturn's Avatar
Default Throttle body selection for LS turbo
Any recommendations of a TB for a mildly ported LS engine with some high lift short duration cams that should be seeing about 300whp?
Old May 5, 2003 | 03:47 PM
hybridEj6's Avatar
Default Re: Throttle body selection for LS turbo (Mr.Saturn)
the bigger the better for forced induction
Old May 6, 2003 | 01:03 AM
Mr.Saturn's Avatar
Default Re: Throttle body selection for LS turbo (ekgsrforu)
brand recommendations?
Old May 6, 2003 | 11:35 AM
Mr.Saturn's Avatar
ttt
Old May 6, 2003 | 11:48 PM
Mr.Saturn's Avatar
ttt again? cmon someone has to know some quality brands, I know main ones like Ericks and stuff, any others that people have good experience with on FI apps?
Old May 7, 2003 | 12:30 AM
MikeMAN's Avatar
i know an-r sells a 70mm one for like $299 shipped..
mike
Old May 7, 2003 | 10:14 AM
Mr.Saturn's Avatar
Default Re: Throttle body selection for LS turbo (MikeMAN)
Any others that people have had experience with?
Old May 14, 2003 | 03:03 PM
hybridEj6's Avatar
Default Re: Throttle body selection for LS turbo (USDMPartGuy)
dont get an str i have a 70mm one and it stuck a lot when i first got it, a lot of people have had bad experiences with str products including cam gears, my str tb always just stuck at idle, now it just does it radomly
Old May 14, 2003 | 07:02 PM
BDL IND's Avatar
That's strange. You should have called us we have 100% customer satisfaction if there is a problem we will try our best to fix it regardless of the problem. I am curious we try to have quality control on all of our parts but sometimes things slip through the cracks. We have sold over 3,000 Throttle Bodies and you are the third person I have heard tell me it sticks the other two made a simple phone call to our shop and we gladly returned their old ones and replaced them with brand new ones. I havent heard a bad thing back from them one called back and said it worked without a hitch. Maybe you should have tried to call us first instead of coming on here badgering the product. Every car in the world isn't perfect there are defects in those, every house, every evrything it is just a matter of how you handle the situation. You can still give us a call and I will still try to help you out. You say it sticks I will remedy the situation.
We do always recommend you do get these products installed by a professional, it eases the headaches the may arise when you're not sure of a proper install.
cmasonrun
May 24, 2008 05:15 PM
Greenery18
Sep 2, 2004 11:47 AM
turbolag98
Aug 20, 2003 05:55 PM
Mr.Saturn
May 9, 2003 12:58 PM
zilverz
Jan 12, 2003 06:21 AM
