Kuhmo tire pressures? SpeedPak
Old Jul 5, 2001 | 05:33 AM
Dropspeed's Avatar
Default Kuhmo tire pressures? SpeedPak
What tire pressures are you Kuhmo v700 tire owners running frt and rr. I'm trying to get a general idea of what other people are doing with the Kuhmos
Thanks Mattj
Old Jul 5, 2001 | 07:10 AM
yoshi234's Avatar
I shoot brides
Default Re: Kuhmo tire pressures? SpeedPak (Dropspeed)
for 225/50F & 205/50R I run 41~43psi F & 45~50psi R for autoX.
yoshi - who hopes this kinda helps
Old Jul 5, 2001 | 07:50 AM
D's Avatar
D
high 30's all around.
generally 38-38.
Old Jul 5, 2001 | 08:01 AM
Brett@SoloRacer.com's Avatar
Usually 40 front (225's), about 37 rear (205's). Higher pressures in the back will allow the car to rotate better, but I didnt like how my car was handling slaloms, so I usually go with 37 rear. Experiment to see what you like
Old Jul 5, 2001 | 08:40 AM
typer_801's Avatar
Default Re: Kuhmo tire pressures? SpeedPak (Tegsport Racing)
39 F (asphalt)
41 F (concrete)
40-44 R (depending on surface, speed, and amount of rotation desired)
Old Jul 5, 2001 | 08:49 AM
AdamITR's Avatar
Default Re: Kuhmo tire pressures? SpeedPak (typer_801)
On RE-10's I ran 38F / 38R cold ... ~41 hot
Old Jul 5, 2001 | 09:04 AM
SpeedPak's Avatar
Default Re: Kuhmo tire pressures? SpeedPak (yoshi234)
225/all around was 42/f 48/r thats for AutoX
for tracks I decreased each by 5 at first and kept reducing depending on how the car felt.
fais
Old Jul 5, 2001 | 09:44 AM
davidnyc's Avatar
Default Re: Kuhmo tire pressures? SpeedPak (SpeedPak)
Last year I was running high pressures (low 40's), but I lowered the pressure to mid 30's this year and I like it better. In the August edition of Grassroots Motorsports they test DOT R-compound tires. They ran the Kumhos at a high pressure first, resulting in disappointing results. They lowered the pressures and had much improved times.(On a road course, not an autox). I can to this same conclusion from my own autocrossing experience. I think the sidewalls of the V700 are stiff enough not to worry about tire rollover. I usually autox on semi-rough ashpalt, outside temperatures in the 80-90's during the summer. Of course, tire pressures depend on surface, outside temperature, driving style, number of runs, etc. etc. The best is to use your own experimentation.
Understeer
Oct 15, 2004 09:58 AM
97dxnut
Apr 26, 2004 06:54 PM
VTECAcuraGSR
21
Apr 16, 2003 02:20 PM
FullMetalJacket
12
Feb 28, 2003 07:32 PM
sykikchimp
11
Feb 3, 2003 05:26 AM
