who has ran this mini me setup
Guest
Posts: n/a
according to this: http://pub143.ezboard.com/fhon...topic it will work. its basicly the same as a y8 motor w/ p29 pistons aside from the fact thats its an a6 block which is basicly the same thing if im not mistaken
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by y49crxsi »</TD></TR><TR><TD CLASS="quote">can you run pump gas with that.... its a really high ratio...</TD></TR></TABLE>
He should be able to run pump gas (93). I'd worry about a GOOD ignition system and good fuel management however
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rasta420 »</TD></TR><TR><TD CLASS="quote">where are the p29 pistons from? also, how would the p29 pistons do in a d16y8 longblock?</TD></TR></TABLE>
p29s are from the d16a1 (88-89 teg ls). you can run 93 octane on that setup w/ good fuel management and ignition like sirx said. this is not a setup for someone who wants to bolt the stuff in and expect it to work properly. it requires extensive tuning.
the p29s will fit fine in any d series block including sohc and dohc zc. d16y8 d16z6 d16a6 d16b7 d15b etc
supposedly (according to a mag- i forgot which one) there is a new 100 octane gas that is being sold in hardware stores or something- so that might be an option. I think that the magazine I was reading was Import Tuner
so what kind of pistons are in the d16a6??
what gives this setup such darned high compression?
what if you used a z6 head? lower compression? still higher than a normal minme?
From: the asshole of america..., upstate new york, USA
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tad »</TD></TR><TR><TD CLASS="quote">so what kind of pistons are in the d16a6??</TD></TR></TABLE>
PM6
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tad »</TD></TR><TR><TD CLASS="quote">what gives this setup such darned high compression?</TD></TR></TABLE>
the P29 pistons sit 0.020" (.5mm) lower in the bore but have a 7.2cc dome vs. the PM6 3.4cc dish. the Y8 head has a smaller volume combustion chamber than the Z6 or A6... Y8=32.8cc Z6=34.6cc A6=38cc
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tad »</TD></TR><TR><TD CLASS="quote">what if you used a z6 head? lower compression? still higher than a normal minme?</TD></TR></TABLE>
Y8 head, Y8 HG, P29 pistons, D16 block ~ 12.61:1 CR
Z6 head, Y8 HG, P29 pistons, D16 block ~ 12.03:1 CR
here: http://www.knology.net/~jediklc/D.htm
what is a <u>normal</u> minime?
PM6
I did the math, if built PROPERLY-it's not as "budget" as many people think
P29 Pistons (.5mm OS) w/ rings~250
Machine work (quote from Bensons)~180
Y8 HG~60
Cam Gear (needed trust me!)~100
After all this, the head and block MUST be flat, if resurfacing is req'd, add that in, then you can't just slap it all together, you need clay for valve to piston clearance
Sure u can do it JY style and find some used pistons,, cut the labor on the machine work and just rehone with Sears type tool and a drill, but don't for get you're dealing with close to 13/1 CR!!!!
Can't mess around with that!!!
Build Properly
Y8 HG~60
Build Properly
projectef
36
May 15, 2007 10:09 PM
