Read this if you've ever considered the "electric supercharger."
Old May 5, 2003 | 12:37 PM
kb58's Avatar
Banned
Default Read this if you've ever considered the "electric supercharger."
While researching (real) turbochargers, I came across some data which will be of interest to anyone looking at the "electric supercharger" sold on Ebay.
1. Required power to deliver 7psi boost to a H22 engine is around 8hp. Yes, eight horsepower. So no matter how the boost is created, it's going to take that much energy to get there. Since the electric supercharge runs on 12V, we can calculate the amps required. 746watts/hp * 8hp = 5968watts. Battery amps = 5868Watts / 12V = 497amps!
2. Their blower is not 100% efficient, due to pumping losses and electrical inefficiencies - their total effeciency is more like 70%. So even if it did work (which it doesn't) it would take even more power than listed above.... 710amps to be exact.
3. The air delivery quoted by the Ebay vendor is with *zero* backpressure. When doing forced induction, you obviously have 7psi backpressure in the above case. Their blower will absolutely not work with this much backpressure, and will in fact reverse flow. So their claim is pure BS in the intended application.
A good experiment to see if you wasted your money, is to set a 7lb object on the outlet of the electric supercharger, then measure the flow. Of course you needn't bother, because the little blower will be unable to lift the restriction...
People who sell stuff like this should be in jail...
Old May 5, 2003 | 12:46 PM
1999all_motoR_teg's Avatar
Default Re: Read this if you've ever considered the "electric supercharger." (kb58)
And people that would even CONSIDER buying something that stupid should never be able to go within 50 feet of a car ever again.
Just the name of the product sounds like a piece of ****.
Old May 6, 2003 | 06:51 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kb58 &raquo;</TD></TR><TR><TD CLASS="quote">3. The air delivery quoted by the Ebay vendor is with *zero* backpressure. When doing forced induction, you obviously have 7psi backpressure in the above case. Their blower will absolutely not work with this much backpressure, and will in fact reverse flow. So their claim is pure BS in the intended application.</TD></TR></TABLE>
Who said that it makes 7psi of boost? If it makes any boost at all its gotta be really small. Otherwise the air being sucked into the engine will probably windmill the thing along, so rather than reversing flow, the engine will be helping to turn that thing faster than the motor would by itself. If it can't keep up by itself, it just adds restriction. How stupid is that?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kb58 &raquo;</TD></TR><TR><TD CLASS="quote">A good experiment to see if you wasted your money, is to set a 7lb object on the outlet of the electric supercharger, then measure the flow. Of course you needn't bother, because the little blower will be unable to lift the restriction...</TD></TR></TABLE>
Actually 7 pounds PER SQUARE INCH of area of the discharge opening. So for a 60mm diameter throttle body, that would be about 30 pounds.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kb58 &raquo;</TD></TR><TR><TD CLASS="quote">People who sell stuff like this should be in jail...</TD></TR></TABLE>
That's called 'free enterprise'. But people who buy it shouldn't be opening their hoods...
What is this thing anyway? A squirrel-cage ventilation blower?
Old May 6, 2003 | 08:55 AM
redneckstanger's Avatar
i geuss i better get rid of mine.
Old May 6, 2003 | 12:15 PM
JimBlake's Avatar
Default Re: (redneckstanger)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redneckstanger &raquo;</TD></TR><TR><TD CLASS="quote">i geuss i better get rid of mine.</TD></TR></TABLE>
Well, does it work? How did your 1/4 mile times compare?
I've never actually seen one, I'm just real suspicious of the description. Like kb58 says, it takes substantial power to do any useful amount of compression... But I think some manufacturers are looking at electrically-driven compressors, but those just aren't the same.
Old May 6, 2003 | 12:25 PM
Default Re: (JimBlake)
I think he's jokin but I could be wrong
Old May 6, 2003 | 12:41 PM
sackdz's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kb58 &raquo;</TD></TR><TR><TD CLASS="quote">1. Required power to deliver 7psi boost to a H22 engine is around 8hp. </TD></TR></TABLE>
Where do you get this figure from?
Old May 6, 2003 | 01:13 PM
wickedEFguy's Avatar
where you that bored to figure that all out? Good analogy though
Old May 6, 2003 | 03:32 PM
Malgerus's Avatar
Default Re: Read this if you've ever considered the "electric supercharger." (Ninja_Jc7)
http://www.homemadeturbo.com/t....html
Old May 6, 2003 | 04:39 PM
Patch's Avatar
Default Re: Read this if you've ever considered the "electric supercharger." (Mr. S)
This sounds almost as dumb as the Hydra-Charger. A hydrualic pump driven compressor. I remember reading about it in Sport Compact Car a while back.
Old May 6, 2003 | 06:20 PM
NonovUrbizniz's Avatar
Loved
Default Re: Read this if you've ever considered the "electric supercharger." (CRX PAT)
you should read more about it....
there has been an update since it was discussed in the issue you're talking about
http://www.sportcompactcarweb....abble/
it was a serious project by GARRETT... if you don't know garrett is VERY reputable and the theory behind the idea is MORE than attainable and would probobly be a GREAT product...
Hydrolic pressure can spin stuff or move stuff WAY more efficiently than air or a pulley... a hydrolically spun turbo would be AWESOME...
if you read the link though garrett dropped it and gave the developement rights to the guy behind the idea who is focusing on long-haul trucking not performance markets... however it also says there is one sitting in jim wolf's garage on a I30... so you never know...
Old May 6, 2003 | 07:02 PM
kb58's Avatar
Banned
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ninja_Jc7 &raquo;</TD></TR><TR><TD CLASS="quote">where you that bored to figure that all out? Good analogy though</TD></TR></TABLE>
No, I just get really pissed to see people knowingly misrepresenting stuff and trying to take advantage of others.
Old May 6, 2003 | 07:06 PM
kb58's Avatar
Banned
Default Re: Read this if you've ever considered the "electric supercharger." (sackdz)
"Where do you get this figure from?"
There's a good spreadsheet program which you can use to calculate turbocharger parameters. I noticed the calculated horsepower and thought it would be a good example about how much power is required to attain a given boost, no matter how it's obtained.
The very useful link is: http://www.gnttype.org/techare....html
The spreadsheet link is at the bottom.
Modified by kb58 at 4:22 AM 5/7/2003
Old May 6, 2003 | 07:31 PM
sackdz's Avatar
Thanks for the link.
Old May 6, 2003 | 07:55 PM
MikeMAN's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX PAT &raquo;</TD></TR><TR><TD CLASS="quote">This sounds almost as dumb as the Hydra-Charger. A hydrualic pump driven compressor. I remember reading about it in Sport Compact Car a while back.</TD></TR></TABLE>
actually the Hydra-Charger is one of the best ideas in a long time. Hardly any parasitic drag like a typical turbo charger + spooling at an insanely low RPM. Would be the best if it was affordable.
mike
Old May 7, 2003 | 12:08 AM
aeolus's Avatar
Default Re: Read this if you've ever considered the "electric supercharger." (JimBlake)
LOL!
Old May 7, 2003 | 04:09 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sackdz &raquo;</TD></TR><TR><TD CLASS="quote">Where do you get this figure from?</TD></TR></TABLE>
Or from almost any first-year thermodynamics textbook.
Old May 7, 2003 | 07:31 AM
kb58's Avatar
Banned
Default Re: Read this if you've ever considered the "electric supercharger." (MikeMAN)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MikeMAN &raquo;</TD></TR><TR><TD CLASS="quote">
mike</TD></TR></TABLE>
I know a guy who was working on such a thing. The nice thing was the flexibility, putting the small pump in one place and be able to put the compressor anywhere. I don't remember the efficiency of the hydraulic compressor though. I know it could be an issue because there's the belt losses, pump losses, fluid flow losses to the compressor, and power transmission losses in the compressor. Still, it seems like a pretty interesting approach... especially if you consider you can use variable fluid flow to provide variable boost at any rpm. You could have a dead flat torque curve. I don't know what happened to the project though and it's been a few years.
Old May 7, 2003 | 09:42 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kb58 &raquo;</TD></TR><TR><TD CLASS="quote">... especially if you consider you can use variable fluid flow to provide variable boost at any rpm. You could have a dead flat torque curve...</TD></TR></TABLE>
Saabs for the last few years have had a very flat torque curve, by modulating the throttle & turbo bypass. So it can be done... They control to torque, so the max boost pressure isn't constant. Lots of stuff to adapt if you wanna do that to another engine, though.
Old May 7, 2003 | 10:49 AM
Default Re: (CIVICVTI2)...........
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CIVICVTI2 &raquo;</TD></TR><TR><TD CLASS="quote">I think he's jokin but I could be wrong</TD></TR></TABLE>
Yeah I was joking.
reddcoupe
Jul 20, 2010 11:53 AM
niceturbo
Oct 11, 2008 04:57 AM
nutball72
31
Oct 17, 2006 08:59 AM
vietnamezeprelude
Feb 25, 2006 04:25 AM
