ugly clutch pedal noise and feel
Old May 5, 2003 | 11:08 AM
magic hat #9's Avatar
Default ugly clutch pedal noise and feel
my car makes a rythmic squeak when i cold start it in the morning. at first i thought it was noisy valves, but i've found the sound immediately goes away when i touch the clutch pedal. i don't even have to depress the pedal; the noise will stop with the lightest pedal pressure. i'm wondering what could cause the clutch to make noise? there hasn't been any change in the clutch operation.
more clutch pedal fun! the pedal gives me a "grinding" feel as it travels through the last 1/2 of the pedal stroke. what kind of lube can be used on the pedal shaft in the footwell?
Old May 5, 2003 | 11:15 AM
Ross's Avatar
25 Year Member
Community Builder
Community Influencer
Active Streak: 30 Days
Default Re: ugly clutch pedal noise and feel (magic hat #9)
I just had my clutch reservoir bled and filled with ATE Super Blue. Made a world of difference, although my problems weren't quite the same as yours. Couldn't hurt to try.
Old May 5, 2003 | 11:31 AM
BudMan's Avatar
pull the release fork boot off of the front of the tranny - you need to put lube in spot where your slave cylinder is pushing on the fork.
You will find it dusty & dry....which is why even the slightest touch stops the sound. Lube it up w/high-temp grease & your good to go as far as the squeaky sound...
Good luck on the grinding portion of your post. You may find the above solves it too.
BudMan
Old May 5, 2003 | 11:44 AM
Default Re: ugly clutch pedal noise and feel (BudMan)
budman, do you think white lithium grease would get the job done? any pictures of the release fork boot? i should be able to get this done tonight.
Jack Black's Avatar
I'm thinking throw-out bearing.
Old May 5, 2003 | 11:48 AM
kepani's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by magic hat #9 &raquo;</TD></TR><TR><TD CLASS="quote">my car makes a rythmic squeak when i cold start it in the morning. at first i thought it was noisy valves, but i've found the sound immediately goes away when i touch the clutch pedal. i don't even have to depress the pedal; the noise will stop with the lightest pedal pressure. i'm wondering what could cause the clutch to make noise? there hasn't been any change in the clutch operation.
more clutch pedal fun! the pedal gives me a "grinding" feel as it travels through the last 1/2 of the pedal stroke. what kind of lube can be used on the pedal shaft in the footwell?</TD></TR></TABLE>
i am experiencing EXACTLY what you describe. i did a clutch fluid bleed/flush yesterday and thought it was gone. but the noise is back and so is the inconsistent engagement.
kepani-who will talk to mikehonda once again...
Old May 5, 2003 | 12:07 PM
Default Re: ugly clutch pedal noise and feel (Agent Smith)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Agent Smith &raquo;</TD></TR><TR><TD CLASS="quote">I'm thinking throw-out bearing.
what are the symptoms of a failed throw out bearing? the car has 42k miles on it and no clutch slippage problems.
Old May 5, 2003 | 12:28 PM
BudMan's Avatar
what are the symptoms of a failed throw out bearing? the car has 42k miles on it and no clutch slippage problems.</TD></TR></TABLE>
It could cause that "rough" feel you described.
As for the boot - I don't have a picture, but you can remove it with your hands & reinsert it into the tranny case when complete = no tools required. I'd spend $3 on high-temp grease if I were you. I don't know if white lithium would end up making a mess! .02
Old May 5, 2003 | 12:29 PM
Jack Black's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by magic hat #9 &raquo;</TD></TR><TR><TD CLASS="quote">what are the symptoms of a failed throw out bearing? the car has 42k miles on it and no clutch slippage problems.</TD></TR></TABLE>
Normally you'll start hearing noise and/or feeling grinding while engaging and disengaging the clutch.
It's a major pain to replace, though (you have to drop the tranny, same as doing the whole clutch), so definitely try to eliminate other causes first.
Old Dec 21, 2003 | 07:55 PM
Ph0eNix's Avatar
I now have the same problem. Can I get this fixed through factory warranty???
Old Dec 21, 2003 | 09:54 PM
Bbasso's Avatar
Because I care about you guys, I have to warn you...
I thought my Throw-out bearing was going before the whole mess with my tranny, So I did the what most people would do... Have a shop that i trusted to yank the tranny out and put in a new tb . But when I went to pick up my car from the shop, the guy said there is something else other then the bearing which seamed rather good... Something inside the tranny is shot. And there is the start of my tranny nightmare.
Just be careful you don't spend the time ot money thinking its just the TB, have someone who knows really take a look and drive.
Good luck.
Old Dec 21, 2003 | 10:22 PM
Ch33se's Avatar
New User
Default Re: ugly clutch pedal noise and feel (kepani)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kepani &raquo;</TD></TR><TR><TD CLASS="quote">
kepani-who will talk to mikehonda once again...</TD></TR></TABLE>
I have exactly the same thing you guys have. Inconsistant engagement (when I'm going uphill from a stop) and sqeeking noise at start up but when I lightly tap on the clucth (dont even need to depress it, just tap) the sqeek gos away?
Old Dec 22, 2003 | 08:13 AM
iperez's Avatar
I've had my car checked under warranty for this at least 3 times. They lube it and it comes right back after 3-4 days. Is there a permanent solution to this ??
Old Dec 22, 2003 | 10:23 AM
typer_801's Avatar
Default Re: (Bbasso)
lol. Two tranny pulls later, I feel your pain. Been there done that. I replaced my TO bearing too to cure some noises when I replaced my clutch. Guess what it wasn't the TO bearing but rather the Input bearings inside the tranny that were making the noise, so in three months I had to pull the box again !
Moral of the story. Don't pull the tranny and replace something unless your absolutely sure that's what's wrong!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bbasso &raquo;</TD></TR><TR><TD CLASS="quote">Because I care about you guys, I have to warn you...
Good luck.
Old Dec 23, 2003 | 04:07 AM
Ph0eNix's Avatar
Default Re: (typer_801)
So can this be fixed through warranty?
Old Dec 23, 2003 | 04:21 AM
Bbasso's Avatar
Default Re: (Ph0eNix)
My tranny was covered under warranty, do search on my name and see what I went through, It was not easy.
Old Dec 23, 2003 | 05:46 AM
Slater's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by magic hat #9 &raquo;</TD></TR><TR><TD CLASS="quote">my car makes a rythmic squeak when i cold start it in the morning. at first i thought it was noisy valves, but i've found the sound immediately goes away when i touch the clutch pedal. i don't even have to depress the pedal; the noise will stop with the lightest pedal pressure.</TD></TR></TABLE>
That sound you desribe is a bad input shaft bearing, not a bad throwout bearing. I've seen it countless times (2 on my personal cars through the years and have seen it on other cars as well).
Bad TO bearings squeak when the clutch pedal is pressed IN and stop when the pedal is OUT (think about how your clutch works). A bad input shaft bearing squeaks when the pedal is OUT but stops as soon as any pressure is put on the pedal.
The IS bearing will get louder with time. It's not hard to replace, just have to open the tranny up and need access to a press. It is definitely a warranty item as long as your car is still under warranty.
Good luck,
- Slater
Sukii
Oct 19, 2012 07:01 PM
kmksub
Honda Civic (2001 - 2005)
Nov 12, 2007 12:07 PM
p1driftfiend
Dec 30, 2003 07:34 AM
stockgreencivic
Apr 1, 2003 07:20 PM
