6 th gen Bottom End
Old May 5, 2003 | 09:19 AM
Al Czervik's Avatar
Default 6 th gen Bottom End
How much horsepower can you add to the 6th gen accord without damaging bottom end? I am thinking nitrous or turbo and am unsure of the limits of stock bottom end. If i need to modify bottom end where can i get parts from?
Old May 5, 2003 | 02:55 PM
all420's Avatar
Default Re: 6 th gen Bottom End (kattiflis)
Do a search. I can garauntee that you will find your answer.
But, I will give some insight. Don't think about turbo with a lot of P.S.I. without upgrading your internals. With nitrous you don't really have to build up anything. Really all you need is colder spark plugs and a better fule pump, and maybe some different injectors, but I have heard people working with less.
Old May 6, 2003 | 05:26 AM
jweller's Avatar
that question is like What is the sound of one hand clapping? unanswerable.
you could add 50 HP, detonate like nobodies business, and launch a rod through the block in 30 seconds. you could add 200 HP, have it perfectly tuned, and never have a problem.
generally speaking, the F23 bottom seems to be fairly stout. search around for dynos of other motors that are about the same as yours and see what they are putting out.
bonh
Aug 4, 2009 07:04 PM
1990hondaHF
Oct 9, 2006 11:06 PM
slow98civicex
Feb 6, 2002 07:56 PM
Knightsport
Nov 9, 2001 03:10 PM
