code 1 after running a stock and chipped p28?
I put a chipped ecu in and ran it hard around the block and then recieved a code1 this is the heated o2 sensor but when I resart the car its off... is this because I am running to rich?
thanks
mike
thanks
mike
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by infamousLSVTEC »</TD></TR><TR><TD CLASS="quote">I put a chipped ecu in and ran it hard around the block and then recieved a code1 this is the heated o2 sensor but when I resart the car its off... is this because I am running to rich?
thanks
mike</TD></TR></TABLE>
..it could be.
What program is on yer P28 ecu? Mugen? if so, it does happen, but it will not hurt your engine performance....just gas mileage performance.
Perhaps its time for a new 02, since you say you get a code 1 with either a stock or chipped P28 ecu.
thanks
..it could be.
Combustion Contraption
May 30, 2004 11:03 AM
