LS ThrottleBody with a CRX manifold port matched.....
Old May 5, 2003 | 08:26 AM
cyberx's Avatar
Default LS ThrottleBody with a CRX manifold port matched.....
i just found out yesterday that my brother had a LS throttlebody off a 92 (i believe) integra.... and its a lil bit bigger then the stock throttlebody prob by 10 mm..... i was wondering if i port matched the intake manifold to the TB if it would make a noticeable diffrence, or a good amount of power gain even if not noticeable.... like say on a Dyno..... ??? thanks
Old May 5, 2003 | 01:41 PM
upstatecrx's Avatar
Default Re: LS ThrottleBody with a CRX manifold port matched..... (cyberx)
a b18a TB is 58mm and a b18b TB is 60mm. all d series are 56 mm so even if you got a b18b its only 4mm bigger not 10mm. it will not add a lot of hp but will help with throttle response. you notice it more if you have a other mods I /H/E, cam , headwork.
Old May 5, 2003 | 04:05 PM
cyberx's Avatar
Default Re: LS ThrottleBody with a CRX manifold port matched..... (upstatecrx)
i got intake headers, cat, midpipe, and exhaut......... 1,000$ head work....... (cam, valves, retainers, etc... but no port and polish)
cyberx's Avatar
i put a vernier caliper up to the throttlebody and it was 63 mm.......
95_red_dc
Jun 13, 2006 07:15 PM
CRXLST
Jan 15, 2004 01:11 PM
ChaseIntegra
Jul 1, 2003 10:50 PM
robbin
Mar 14, 2002 07:16 PM
