JDM vtec solenoid VS USDM vtec solenoid??
i bought a JDM itr motor swap and it came with a vtec solenoid that only has one gray plug w/out the usual green plug found on the usdm vtec solenoid...i know that jdm vtec solenoid is contorlled by ecu....my Q is...how can i use this vtec solenoid with the USDM ECU? or i can't and i should just buy a USDM vtec solenoid ?(green plug with gray plug)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pinota »</TD></TR><TR><TD CLASS="quote">Just jump your solenoid vtec wire into your ECU (back block) oil pressure switch pin.
so i should run the oil pressure switch wire from the ECU to the back of the block's pressure switch pin? just want to makre sure
dont want to mess my fren up...thanks
89sparks
Sep 4, 2007 06:35 PM
the soL that could
13
Mar 21, 2006 12:32 PM
