necessary to remove hubs to install extended lugs?
Old May 4, 2003 | 09:17 PM
spettinger's Avatar
Default necessary to remove hubs to install extended lugs?
i will soon be putting on some skunk2 extended wheel studs onto some DA knuckles, is it necessary to have the hubs pressed out to install new lugs? or will i be able to fit them in with the knuckle fully assembled?
Old May 4, 2003 | 10:03 PM
zulued's Avatar
Default Re: necessary to remove hubs to install extended lugs? (2ndhandCRX)
yes you can change the lugs with out disassembling the knuckle ... but there is only one spot that the hub can be turned to do so... look at the back of the knucle assembly and find that spot and remove the old one put the new one in and turn it to the next one. and so on
scarponze
kornerk12
Aug 8, 2008 08:32 PM
crv-techu
Jun 10, 2008 01:51 AM
ALLMOTOR CRX
Mar 14, 2007 10:08 PM
RTW DC2R
Feb 13, 2006 08:21 PM
david90
Jun 8, 2004 02:47 PM
