'homemade' radiator hose... will this be alright? pics
Hey... I needed a radiator hose that snaked under the piping for my turbo... so I combined two hoses and used a copper elbow. Will the copper corode in any way? The ID of the copper elbow is very similiar to the ID of the radiator hose...
if you wanted to be extra careful, you could try and find a high temp silicone or other sealent, and then put 2 hose clamps at each end. just check it everyonce in a while to see if there are coolant stains on the hose
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bob-DC2 »</TD></TR><TR><TD CLASS="quote">if you wanted to be extra careful, you could try and find a high temp silicone or other sealent, and then put 2 hose clamps at each end. just check it everyonce in a while to see if there are coolant stains on the hose</TD></TR></TABLE>
good advice... thanks! I tried to find a radiator hose for a honda that would fit that shape... and i got aone for a CL but it didnt fit right so i cut it the way i needed to and just used the elbow
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbogixxer »</TD></TR><TR><TD CLASS="quote">it will be ok. Most radiators are made of copper. </TD></TR></TABLE>
i thought radiators were made out of aluminum?
mike
mike
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MikeMAN »</TD></TR><TR><TD CLASS="quote">
mike</TD></TR></TABLE>
haha.... but i guess its ok since they make those copper radiator stop leaks, and since you put copper spray on your headgasket.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18EG6 »</TD></TR><TR><TD CLASS="quote">
haha.... but i guess its ok since they make those copper radiator stop leaks, and since you put copper spray on your headgasket.</TD></TR></TABLE>
yea, i understand that..i was just puzzled when it was stated they are made out of copper
hehe
mike
hehemike
Most OEM radiators are made of copper. Now they are starting to use a plastic and aluminum hybrid for weight and cost. But for a good 40 years, all the radiators were copper.
EDIT: most race radiators are made out of aluminum because they ex-spell heat fast and are lighter.
EDIT: most race radiators are made out of aluminum because they ex-spell heat fast and are lighter.</TD></TR></TABLE>
is there a coating on mine that makes it look silver then?
mike
mike
wdskuk
12
Jan 24, 2004 09:38 AM
