ls vtec or high compression b16a with cams
Old May 4, 2003 | 04:37 PM
khcivic's Avatar
Default ls vtec or high compression b16a with cams
ok i have a b16a in an eg hatch . i bought a ls long block and 11.5-1 pistons for it to build an lsvtec. but should i build my b16a. what will make more power and i wont have to worry about problems with.im a actual honda tech so im mechanicly inclined. just caught in a situation what to do any sugestions
Old May 4, 2003 | 04:39 PM
BerlinaAP2's Avatar
Default Re: ls vtec or high compression b16a with cams (khcivic)
build the b16
Old May 4, 2003 | 04:50 PM
civicturbo92's Avatar
Default Re: ls vtec or high compression b16a with cams (ApexiSi)
If your building the car for autocross build the b16, but if your going for all out hp build the ls
Old May 4, 2003 | 05:10 PM
KoRE's Avatar
Default Re: ls vtec or high compression b16a with cams (civicturbo92)
LS/Vtec that's what i'm going....
if you do it right just as reliable... more power
Old May 4, 2003 | 05:19 PM
sander's Avatar
2.7(p/t)
b16s have a perfect R/S ratio for reliablity and good safe high revving.
it is undeniable that ls/vtecs have good torque, but they also have a less than good R/S ratio resulting in higher cyl wall wear due to the more aggressive angle of piston descent in the motor. (my prefrence is ls/vtec becuase the power and torque is amazing, but i like b16s too).
-sander
Old May 4, 2003 | 05:33 PM
dfoxengr's Avatar
Default Re: ls vtec or high compression b16a with cams (jazzyfoo)
r/s isnt as horrible as people make it out to be with lsvtec and stock strokes....
Old May 4, 2003 | 06:40 PM
khcivic's Avatar
Default Re: ls vtec or high compression b16a with cams (hybridvteceg)
well i can probaly swap my pistons for some skunk2 cams, and i have a 88 civic that i want to turbo so i have alot of options. too many maybe lol
hatchvtec
33
Mar 22, 2007 02:53 PM
GreenMachineRex
22
Jan 24, 2006 01:17 AM
2ndgenluis
Sep 15, 2005 09:15 PM
redciviclx14
Aug 14, 2003 08:34 AM
