Question on MPFI swap
I have a 90 civic std with just about everything for the swap except distributor which I expect to be getting soon..I see that my car has Honda Canda does that mean wiring is different?
http://www.we-todd-did-racing....3D%3D
My question is concerning injector wiring they say that you must connect yellow/black wires from injectors to yellow black wires from injector resistor box as you can see my wires seem to be different..If anybody can shed some light on what need to be done would appreciated. Thanks
Modified by Kilohead36 at 3:41 PM 5/4/2003
Modified by Kilohead36 at 3:42 PM 5/4/2003
Just connect the yellow black from the injector to resistor box to that thick yellow black in that pic. Then run all 4 injector grounds to the resistor box (red/black). Then run your injector wires either from the inj to ecu or run the 2 inj's to the existing inj's from the dx harness and the other 2 to the ecu...
markgo
Nov 8, 2006 11:39 AM
