Removing the head from the block
Old May 4, 2003 | 01:50 PM
RacerZook's Avatar
Default Removing the head from the block
Has anyone removed the head from the block while theengine was still in the car? I'm thinking about attempting this so that i can save about 300 to have the head ported. How hard is it? Anything particularly hard about it? How long should it take? I guess my main worry is putting it all back together and that it all lines up correctly.
Thanks
BTW, this is going to be done on a gsr (don't think it's much different than doing it on an ITR block). It just seems that there is more mechanically inclined people on this forum than the regular integra one
Old May 4, 2003 | 01:54 PM
baonest1's Avatar
Default Re: Removing the head from the block (RacerZook)
i just did this last week. just remove the wiring harness. i like to keep the intake mani on for an extra handle, dont know bout GSR but the type R head has 2 bolts holding the intake mani on a bracket. remove PS pump and all coolant hoses. unbolt the headbolts from outside to in to prevent warpage, this goes for the cam tower things too.
oh and get a helms that helps too. took me like 45 min.
Old May 4, 2003 | 03:07 PM
.RJ's Avatar
.RJ
Its not that hard. Pull the exhaust manifold bolts and brackets off, pull it off and below the head. Remove cam cover and all the emissions and fuel stuff off the manifold (remove everything and the harness plugs next to the driver side shock tower and set everything over next to the battery. Remove p/s bolts (dont unhook lines), middle timing belt cover, loosen tensioner, pull belt off. Remove cams... unbolt head and take head/IM off together.
Old May 4, 2003 | 05:13 PM
baonest1's Avatar
Default Re: Removing the head from the block (.RJ)
his was more detailed. listen to him.
Old May 4, 2003 | 05:40 PM
VTEC-DA's Avatar
Default Re: Removing the head from the block (baonest)
Its not to bad. Everything is pretty straight forward, just remember the couple bolts holding the IM bracket to the block. I forgot those the first time I did it and stood around trying to figure out why it wouldnt come off.
Old May 4, 2003 | 05:43 PM
baonest1's Avatar
Default Re: Removing the head from the block (VTEC-DA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTEC-DA &raquo;</TD></TR><TR><TD CLASS="quote">Its not to bad. Everything is pretty straight forward, just remember the couple bolts holding the IM bracket to the block. I forgot those the first time I did it and stood around trying to figure out why it wouldnt come off. </TD></TR></TABLE> lol. similar to what i did. i loosened the head nuts (i have ARP studs) and after i disconnected everything i was really wondering why the head wont come off.. then i remembered the nuts are still there
Old May 5, 2003 | 04:35 PM
RacerZook's Avatar
There weren't any hard to reach bolts or "difficult situations" you guys ran into? I'm just tryin' to figure out the potential of the "oh ****" mishap. And when you bolt it back on, just line up the TDC mark on the crank and line up the cams at tdc too right?
Old May 5, 2003 | 04:39 PM
.RJ's Avatar
.RJ
line it up to TDC before you pull the head off
difficult bolts? not really.... all the little clips holding the connectors and **** on are a pain.
Old May 5, 2003 | 04:40 PM
.RJ's Avatar
.RJ
https://honda-tech.com/zerothread?id=495880
Old May 5, 2003 | 05:31 PM
B2FiNiTY's Avatar
Wow, doesn't seem that bad
B2 - who might have to do this soon.
Old May 5, 2003 | 05:37 PM
.RJ's Avatar
.RJ
Default Re: Removing the head from the block (B2FiNiTY)
Dont forget to order new gaskets. all of them. because the one you dont have is the one thats not re-useable.
Old May 5, 2003 | 06:12 PM
RacerZook's Avatar
what else besides head gasket, IM gasket, Cam seal and maybe header gasket would I need?
Old May 5, 2003 | 06:13 PM
.RJ's Avatar
.RJ
Exhaust manifold gasket, throtte body gasket. And some liquid gasket for the cam seals.
Old May 5, 2003 | 06:17 PM
arren123's Avatar
Heck.. While you have it off, you might as well do the timing belt and water pump too.. And don't forget a valve adjustment.
journeyquest
May 10, 2011 11:30 AM
junior40er
24
Jun 21, 2006 10:52 AM
RACING INTEGRATION
Dec 5, 2005 10:43 AM
