key for speed not working
Old May 4, 2003 | 12:39 PM
1bad_crx's Avatar
Default key for speed not working
Just got my swap done(thank u jesus) and for some reason my key wont come out the ignition. What could it be or do i need a new ignition. any input. also would this cause my battery to drain. thanks in advance.
Old May 4, 2003 | 12:59 PM
durrett syndrome's Avatar
Default Re: key for speed not working (1bad_crx)
just turn the key and pull while your turning the steering wheel and it should evenually come out if thats the problem your talking about.
Old May 4, 2003 | 02:11 PM
Jaker's Avatar
Was your car automatic before the swap? If so, you need to disable the neutral/park safety switch.
Old May 4, 2003 | 07:21 PM
1bad_crx's Avatar
Default Re: key for speed not working (Jaker)
i get no luck when trying to turn the wheel and pull the key. yes the car was an automatic. How would i disable that safety switch. i think i disabled that to actually get the car to start. but maybe i missed a step.
Old May 5, 2003 | 04:46 AM
1bad_crx's Avatar
Old May 5, 2003 | 12:21 PM
1bad_crx's Avatar
ttt need more info
Old May 5, 2003 | 03:08 PM
Jaker's Avatar
There are 2 different hook ups that were at the auto shifter. 1 is the neutral safety switch, to prevent you starting the car when its in gear, and the other is the park switch so you can't get out of your car without 1st putting it into park, and then taking out the key. There is a solenoid on the steering column that locks the key in the ignition switch, until the sensor at the auto shifter detects that the car is in park. Just have to find the right 2 wires for that switch, and join them together.
Old May 5, 2003 | 03:44 PM
RCautoworks's Avatar
Here is how you do it
http://hometown.aol.com/jrmupzaii/auto2man.html
nicknoble
Apr 1, 2019 01:22 PM
prodjay10
Honda Civic (2001 - 2005)
Mar 27, 2016 08:59 PM
safedriver
May 25, 2012 02:48 AM
luder916
Feb 19, 2010 09:23 AM
dieselgg
Sep 17, 2006 06:55 PM
