B17 swap info???
Old May 3, 2003 | 09:34 PM
blacksheep's Avatar
Default B17 swap info???
What does it take to put a B17A swap into a 91 DX hatch? I know I'll need a mount kit, but I'm really not sure of what to do on the wiring end. Do I just use all the stuff from the B17, and just use OBD-1? Or do I have to stay OBD-0?
Old May 3, 2003 | 10:32 PM
russian_racer's Avatar
Default Re: B17 swap info??? (blacksheep)
I had my b17a put in a dx crx (I didnt do the work)....but...I stayed with obd0 and had a b16a ecu put in...you could run obd1 if you wanted to keep your b17 ecu...(I hear the b16 is a better ecu though)
Old May 13, 2003 | 01:08 AM
blacksheep's Avatar
Default Re: B17 swap info??? (russian_racer)
So to run OBD-1 do I need to use the wire harness from the Integra or modify the one in the hatch?
Old May 14, 2003 | 05:48 PM
fourthgenhatchB17's Avatar
to run OBD-1 in a 88-91 civic/crx u need a obd 0-1 jumper harness ( or u can rig it ) and u will need to modify ur existing harness thats on ur DX motor. Or u can find an SI harness and modify that one slightly. Integra harnesses will not work.
Old May 14, 2003 | 11:19 PM
blacksheep's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fourthgenhatchB17 &raquo;</TD></TR><TR><TD CLASS="quote">to run OBD-1 in a 88-91 civic/crx u need a obd 0-1 jumper harness ( or u can rig it ) </TD></TR></TABLE>
Where can I get this jumper harness?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fourthgenhatchB17 &raquo;</TD></TR><TR><TD CLASS="quote">and u will need to modify ur existing harness thats on ur DX motor. Or u can find an SI harness and modify that one slightly. Integra harnesses will not work.</TD></TR></TABLE>
And where can I find instructions on how to modify my existing harness? or Si harness if I have to use that?
Old May 16, 2003 | 07:00 AM
blacksheep's Avatar
Default Re: (blacksheep)
well...? guys?... i need some answers.. somebody help me with this.
Old May 18, 2003 | 10:33 PM
Alright, i got my jumper harness from a guy named Jesse in Washington. He sold one to me for 160$ shipped and it came with all the necessary conversion literature for converting an 88-91 civic/crx SI to OBD-1. So if u have a DX harness then u will have to convert to MPFI/Si model. EMAIL this guy &gt;&gt;&gt;&gt; jesse brittsan &lt;jesse@urbanimports.org&gt; He should set u up with all u need to know about the conversion.
Old May 27, 2003 | 09:26 AM
blacksheep's Avatar
Thanks man I'll email him tonight.
Old May 27, 2003 | 12:22 PM
4crx4me's Avatar
I'm doing the same swap in the next couple of weeks.
I'm gonna get my OBD0 - OBD1 harness from "blown90hatch".
Do a search on his name everybody here his products.
And also do a search on "B17" and "Obd conversion"
Hope that helps.
Old May 27, 2003 | 12:29 PM
slowpokesi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blacksheep &raquo;</TD></TR><TR><TD CLASS="quote">well...? guys?... i need some answers.. somebody help me with this.</TD></TR></TABLE>
dude help yourself, this **** has been asked a million kazillion times, do a search.
954 veteran
Jun 16, 2009 01:42 PM
93siturbo
Apr 10, 2009 06:22 PM
nitroracer
Sep 9, 2006 07:50 PM
E_F_9
Dec 25, 2005 07:36 PM
