How can i clean this (56K don't try)
Old May 3, 2003 | 08:40 PM
sshaikh01's Avatar
Default How can i clean this (56K don't try)
As you can see the pistons took a lot of beatings.
How can i clean the pistons and the mating area of head and block.
are you sure these pistons come in silver, they sure don't look shiny silver.
close up of the piston.
What is the best way to clean this **** up, inlcuding the pistons.
Old May 3, 2003 | 08:53 PM
sshaikh01's Avatar
Default Re: How can i clean this (sshaikh01)
are you guys able to see the pics or is we-todd taking a crap
Old May 3, 2003 | 09:09 PM
Rob Dizzle's Avatar
pics are fine
the easiest way to clean it is to get new pistons
im not sure what motor you have
but you can get new us itr pistons with rings for 150 shipped from a couple places including me
Old May 3, 2003 | 10:42 PM
sshaikh01's Avatar
Default Re: How can i clean this (Bob-DC2)
would the itr pistons bit my madza mpv ??
Old May 3, 2003 | 11:59 PM
sshaikh01's Avatar
can i use sand paper to sand it down ??
Old May 4, 2003 | 01:13 AM
sshaikh01's Avatar
ttt
Old May 4, 2003 | 02:47 AM
blufke's Avatar
yeah i was wondering about the pistons. 2 valves on one side and a big valve on the other.
Old May 4, 2003 | 07:32 AM
DEVIN22CBR's Avatar
Default Re: How can i clean this (PIMPASSBEOTCH)
dont touch the cylinder walls!
Old May 4, 2003 | 08:12 AM
sshaikh01's Avatar
Default Re: How can i clean this (blufke)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blufke &raquo;</TD></TR><TR><TD CLASS="quote">yeah i was wondering about the pistons. 2 valves on one side and a big valve on the other.</TD></TR></TABLE>
you wanna see the valves
Head #1
head #2
close up
So if i use sandpaper on the block surface mating area it won't hurt.
Keep the comments comming guys.
Old May 4, 2003 | 08:20 AM
TREVER's Avatar
don't touch just put it back together and run some carbon cleaner through it
Old May 4, 2003 | 08:30 AM
sshaikh01's Avatar
Default Re:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TREVER &raquo;</TD></TR><TR><TD CLASS="quote">don't touch just put it back together and run some carbon cleaner through it </TD></TR></TABLE>
I'm sending the heads to the machine shop, i know the mating area of the head and the block should be clean, so i just wanna clean that **** up so wanted to know what exactly can can't i do.
Also i have oil in my intake manifold, so i wanna clean that **** up as well.
Old May 4, 2003 | 09:39 AM
94hatch's Avatar
Looks like you need a new set of pistons. That one on the end looks chipped or melted.
Old May 4, 2003 | 09:53 AM
Tuney's Avatar
Default Re: How can i clean this (94hatch)
just leave it on there, more compression for joo
Old May 4, 2003 | 10:53 AM
sshaikh01's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94hatch &raquo;</TD></TR><TR><TD CLASS="quote">Looks like you need a new set of pistons. That one on the end looks chipped or melted.</TD></TR></TABLE>
Pistons is not chiped, the black burned oil is chipped
Old May 4, 2003 | 01:55 PM
dfoxengr's Avatar
is this a geo 3cyl?
Old May 4, 2003 | 01:59 PM
altoid's Avatar
Default Re: How can i clean this (hybridvteceg)
carb cleaner cleans stuff up quite well for me, may wanna try that on the mating surface, i'd run some chevron techron after its all back together and that cleans injectors and carbon deposits.
Old May 4, 2003 | 02:40 PM
rob d's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybridvteceg &raquo;</TD></TR><TR><TD CLASS="quote">is this a geo 3cyl?</TD></TR></TABLE>
V6
sshaikh01 : Give deisel fuel a try.
Old May 4, 2003 | 02:43 PM
dfoxengr's Avatar
Default Re: How can i clean this (rob d)
haha damn....3cyl owns..
Old May 4, 2003 | 02:49 PM
GZERO's Avatar
guys it's a V6 so stop saying 3 cyl! lol
you can try several things, but you have to keep in mind you have to change the oil before starting it the first time after this rebuilt. you can use Catrol cleaner (forgot the name, somebody remember it?), you can use ATF, or any other degreaser like a carb cleaner or whatever, i guess diesel fuel will work, but be carefull, i wouldn't recomend sanding the top of the block, i guess it would make the block less flat (don't have the correct term on my mind right now) than what it is right now, and you will make the block more prone to warp, just my $.02
Old May 4, 2003 | 03:12 PM
vtec69's Avatar
Default Re: How can i clean this (GZERO)
try using a carb cleaner and a tooth brush or a soft wire brush
Old May 4, 2003 | 06:28 PM
sshaikh01's Avatar
Here is to your geo
too bad this geo has got a V6 16 valve 3.x lit. engine in it
Old May 4, 2003 | 06:30 PM
sshaikh01's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rob d &raquo;</TD></TR><TR><TD CLASS="quote">
V6
sshaikh01 : Give deisel fuel a try.</TD></TR></TABLE>
So, if i take deisel fuel old t-shirt and my cousin's toothbrush
it should do the trick.
Old May 4, 2003 | 06:38 PM
rob d's Avatar
I tried it. Works great.
Old May 4, 2003 | 08:33 PM
GZERO's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sshaikh01 &raquo;</TD></TR><TR><TD CLASS="quote">
Where did the engine go?
Old May 20, 2003 | 05:45 PM
sshaikh01's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GZERO &raquo;</TD></TR><TR><TD CLASS="quote">
Where did the engine go?</TD></TR></TABLE>
ssshh
i was hoping no one will notice.
sk8board{Pete}
Oct 19, 2008 12:07 PM
GSRCRXsi
Apr 23, 2007 03:30 AM
Eluzion
Jun 2, 2004 05:25 PM
hondaeg8
Jan 6, 2004 05:08 PM
