Suspension skips over bumps..
crx with es bushings/koni/eibach. When i go through corners and hit some little bumps its not soaking them up it just skips and u feel it through wheel. Car is also really wondery u gotta white knuckle it wiht both hands. Everything is within spec i just had it checked. Any ideas?
how much is the car lowered? maybe the shocks are set to stiff. i wouild also recommoned getting a camber kit and getting wheel alignm,ent and balanced. if this doesnt help then you probably have a control arm bent or something. this could solve the wandering.
Its the eibach pro-kit so 1.5 or so maybe alittle more. I do have a camber kit its the progessive one. I had the alignment and balance done. Also i have played with the konis on softest and hardest it still skips. Heres specs...
left camber (-0.9) toe (0.06) caster (2.2)
right camber (-0.8) toe (0.06) caster (2.5)
TEG98
Apr 6, 2003 08:33 AM
