What Is It ??
Old May 3, 2003 | 05:17 PM
steelbuster's Avatar
Default What Is It ??
There is a small diaphram on the end of the fuel pipe on my JDM B16 SiR engine that is part of the nut which fastens the fuel supply hose to the fuel pipe. The parts book lists it as a "Damper Assembly,Pulsation". Apparently, it dampens the pressure pulsations from the fuel pump.
When I removed the plastic cover, there was a small screw laying loose inside that had fallen out of the center of the diaphram case. This screw seems to be an adjustment screw, as when turned in it opens a valve(?) in the assemble.
The question I have is how to set this adjustment screw, if that is in fact what it is?
sgull
Jan 25, 2013 12:43 PM
mstewar
29
Mar 28, 2005 11:11 AM
sleeperb16a
Sep 7, 2004 07:57 PM
RTW DC2R
Jan 22, 2004 01:01 PM
18gsir
Jul 23, 2003 12:26 AM
