Why do I need to do a valve adjustment if...
Well I got the timing belt on today...started the car... and heard a LOT of ticking. If everything is at TDC, and stays at TDC....does this mean I need to do a valve adjustment?
This is the first time doing a valve adjustment myself, although I have watched others do it. I adjusted the intake's to .006, and the exhaust to .007. I did them in the correct order, 1342, and did it till I felt a slight drag on the feeler gauge. I made sure the screw did not loosen while I tightened the nut.
Why does my motor tick so loudly? Is it the stupid LMA's? Argh... I just wanna drive my car for once in 4 months
Any suggestions? I only come back maybe once or twice a month.
.Any suggestions? I only come back maybe once or twice a month.
are u getting spark on all the spark plug wires,cause my wass doing a loud ticking noise cause the car was running on 3 cylinders.the distributor cap was faulty,after i change it the engine started fine and the ticking was gone.
My friend recently got a valve adjustment on his GSR at the Acura dealership and it was really ticky afterwards. Thats just how they sound I guess.
Yes I am getting spark to all 4 cylinders
Before I did all the work, my motor was nice and quiet though... This ticking is REALLLY loud, almost sounds like the valves hitting the pistons... but its not since everythign is at TDC.
Tomorrow I will go and maybe tighten them a little more if my damn back stops hurting from being bent over for the whole day...
Modified by B18EG6 at 3:23 AM 5/4/2003
Marcg611
Aug 24, 2008 08:04 AM
supadupamikey
Aug 15, 2001 05:10 AM
