Viper 550esp.... lights dont blink anymore
Old May 3, 2003 | 03:37 PM
B18EG6's Avatar
Default Viper 550esp.... lights dont blink anymore
Hello- I have a Viper 550 esp and when I arm/disarm the alarm, the lights no longer blink. I checked the 15amp fuse for the lights and it is good... I also put a multimeter in the terminals of the fuse holder, and it read somewhere around 12v when I arm/disarm the alarm. The lights also work normally via the stock lightswitch.
What do you suggest I do?
Old May 3, 2003 | 09:22 PM
audioroach's Avatar
Default Re: Viper 550esp.... lights dont blink anymore (B18EG6)
Hmmm...lets see now
a. you checked the alarm and it flashed 12v upon arm /disarm based on a
multimeter measurement...okay that rules out a busted/frozen relay
b. you pulled the fuse and found out that the car shows 12v when lights
are on through the alarms fuse holder right?....if so you dont have a broken
connection in the wiring.
c. you pulled the fuse and it "looked" good....a fuse is duty rated for
X hours...it can burn a slow trace instead of a catastrophic one...I think you
found the weakest link.
If senario a and b are correct...just replace the fuse and it will work good as new.
laterz
Old May 3, 2003 | 11:20 PM
B18EG6's Avatar
Default Re: Viper 550esp.... lights dont blink anymore (audioroach)
I did replace the fuse.... twice
Ima replace the fuse with a wire, is that a wise idea?
Old May 4, 2003 | 07:34 AM
audioroach's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18EG6 &raquo;</TD></TR><TR><TD CLASS="quote">I did replace the fuse.... twice
Ima replace the fuse with a wire, is that a wise idea?</TD></TR></TABLE>
Don't do it !!!....if the fuse is blowing after you replace it
and test the system...you have a dead short in the system. It needs
to be fixed before other problems arise.
Old May 4, 2003 | 04:17 PM
B18EG6's Avatar
the fuse didnt blow. I just meant I replaced it to see if it was a poopy fuse. The fuse is fine.
any other suggestions?
Old May 4, 2003 | 10:33 PM
99turbosi's Avatar
Turn on your parking lights and test the white parking light wire coming out of the brain, if it shows that you have 12 volts on the white wire when the parking lights are on then your connection is fine. You can also put a 3-5 amp fuse on a piece of wire and jump it over to the red wire on the brain (12v constant) and see if the parking lights flash when u touch the wires together ... just make sure you use a fuse to protect the circuits on the brain and in the car. If neither work take the brain back to a circuit city, DEI products are guarenteed for life and they can warranty it for you there as will any autoorized DEI dealer.
Old May 4, 2003 | 10:39 PM
B18EG6's Avatar
Default Re: Viper 550esp.... lights dont blink anymore (99turbosi)
Awesome suggestion! Im going home again in two weeks, I will try this.
lets see... with my parking lights on, and i test the white wire... can i just remove the fuse and look for voltage there?
and also.... does dei make the viper products?
Old May 5, 2003 | 09:36 AM
dabrown's Avatar
I have no clue but I have bought several Viper Alarms in the past and they all have done this to me. They were installed by pro's. I am no longer going to buy a viper for this reason. I think that clifford is made by DEI electronics as well so it looks like I will take that chance again!!!! But if you find out let us know..
Old May 5, 2003 | 10:31 PM
99turbosi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18EG6 &raquo;</TD></TR><TR><TD CLASS="quote">Awesome suggestion! Im going home again in two weeks, I will try this.
and also.... does dei make the viper products?</TD></TR></TABLE>
You can look for voltage there ... that is just an easy way to make sure that the connection between the parking light wire on the brain and the wire in the car are good. yes Viper is a DEI product. Make sure that the wire that u connected to is a red wire with a black stripe on the back of the dimmer switch, but make sure that that wire does not drop to ground when you dim the dash lights down, if it does find another source. If you really get stuck let me know I have been installing professionally for 6 years now and I will try to talk you through it over the phone ... i know how frustrating it can be. good luck.
Old May 6, 2003 | 09:09 AM
B18EG6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99turbosi &raquo;</TD></TR><TR><TD CLASS="quote">
thanks a lot man... id appreciate help on the phone if you would be willing to do that for me. I wont be home till the 20th though , you sure you wouldnt mind helping if i get stuck up?
Old May 7, 2003 | 11:28 PM
99turbosi's Avatar
not a problem, just let me know.
Old May 9, 2003 | 08:11 PM
Quad-Damag's Avatar
Default Re: (99turbosi)
Get a new Alarm the Viper 550 isn't going to stop any theifts
Old May 10, 2003 | 10:17 AM
B18EG6's Avatar
Default Re: (Quad-Damge)
Wellll..... I dont have any loot, and if i did i wouldnt feel like installing a new one unless I can reuse the wires/harness.
What alarm would you recommend, and why do you think my alarm is inept?
Old May 10, 2003 | 06:53 PM
Quad-Damag's Avatar
Default Re: (B18EG6)
Clifford Vangurd, is my #1 One Unit in my book, i got a Viper/Cliffort Custom Alarma and it rocks Viper Pager Clifford Suceirty
Old Oct 19, 2003 | 07:59 PM
integra*RS*'s Avatar
New User
need help too!
It chirps but no light blinking
Old Oct 20, 2003 | 04:46 AM
rjr162's Avatar
Default Re: (integra*RS*)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">I have no clue but I have bought several Viper Alarms in the past and they all have done this to me. They were installed by pro's. I am no longer going to buy a viper for this reason. I think that clifford is made by DEI electronics as well so it looks like I will take that chance again!!!! But if you find out let us know..</TD></TR></TABLE>
Never had this problem is the hundreds I've installed....
Old Oct 20, 2003 | 08:32 AM
New User
Default Re: (rjr162)
can anybdy help me out with this problem.....no lights blinkin'
Bruce Banner
Mar 1, 2008 05:09 PM
-Championship-
Audio / Security / Video
11
Sep 18, 2006 01:18 PM
jdmeg9
Apr 30, 2005 08:03 AM
SlamMan
Jun 15, 2003 12:00 AM
B18EG6
Feb 11, 2003 05:08 PM
