wierd idle
Old May 3, 2003 | 03:29 PM
honda8882's Avatar
Default wierd idle
my idle bounces up and down when the car is cold for about 5 min, then it goes normal. what do you guys think. i have no cel. i also have a brake pressure problem because i am losing pressure but i have no leaks and the master cylinder appears to be ok. i was told that the idle issue could be affecting the master cylinder if there is a iac problem. what u guys think
Old May 3, 2003 | 06:30 PM
Razor's Avatar
Default Re: wierd idle (honda8882)
maybe a loose vacuum line or your FIV is going bad.
Old May 4, 2003 | 01:56 PM
honda8882's Avatar
Default Re: wierd idle (Razor)
the fast idle valve is completely separate from the iac isnt it?
Old May 6, 2003 | 09:42 AM
BrokenWindows's Avatar
same issue man, start it up or put it in park when cold and it revs like a renob. my vacuum hose was just flopping around under there. i must have cut it when installing my CAI. So I T-Piped it to my CAI outlet and my car hauls bauls.
Old May 7, 2003 | 06:52 AM
honda8882's Avatar
Default Re: (BrokenWindows)
what hose are u talking about? are you talking about the one that goes from the top of the valve cover to the cai pipe?
weaslehunter1
Jan 26, 2015 03:49 PM
beho
May 12, 2006 02:59 AM
LoSt is BlaCk
Mar 26, 2004 05:07 AM
blackhatchy
16
May 21, 2003 06:31 PM
