balance shaft probs
well i did mine today....and it revs way faster...it idels better than ever wich is kinda wierd??...but any way ive got a nasty vibration around 7000rpm....it just doesnt feel right .....
i did notice a couple of chips on my crank pully...not to big but good enough to notice with out looking for them....could a bad cluthc also make this vibration
man ive always had a concern about doing that on a hseries motor...people say you dont need that on engines smaller than 2.0ltr we are 2-3liters over...i dont like the idea...b and d series yeah but not on my h
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by machine4321 »</TD></TR><TR><TD CLASS="quote">well i did mine today....and it revs way faster...it idels better than ever wich is kinda wierd??...but any way ive got a nasty vibration around 7000rpm....it just doesnt feel right .....</TD></TR></TABLE>
Honda engineers put the balancer shafts in the engine to reduce vibrations. It should be no big surprise that the engine feels rougher and tranfers a lot more vibration to the chassis after you removed them...
Andrew
Andrew
ya ..like i said its smotther at idel then ever before...it just doesnt feel like it wants to rev to red
could it be the crank pully...its all chiped some are big
man i had my balancer belt replaced a lil ago and since then whenever my motor gets in the higher rpms it vibrates a lot more and makes the dash rattle. its scary at times but im getting use to it..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ludedudesi »</TD></TR><TR><TD CLASS="quote">hmm well i dunno. this wouldnt hurt anything if my belt wasnt balanced properly would it</TD></TR></TABLE>
It is possible that the alleged technician installed your belt with one of the shafts 180* off. This would cause some nasty vibrations, but probably throughout the RPM range.
You can always reinstall the balance belt, to see if that problem goes away. A bad crank pully will result in it being out of balance. So yes, it will make a difference.
Oct 5, 2006 05:17 AM
