mugen mf10's w/ endless calipers???
will 16x7 et+43 mugen mf10's fit w/ endless calipers? or would i have to buy the +50 offset? BTW, this will be on my EK. any help would be appreciated.
Have you asked in the ITR forum yet?
From what I understand, you may need 17s in order to clear the calipers.
I know a friend of Yoshi's has those calipers.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Green R »</TD></TR><TR><TD CLASS="quote">Have you asked in the ITR forum yet?
I know a friend of Yoshi's has those calipers.</TD></TR></TABLE>
i asked in the itr forum also...just wanted to see if anybody here would know too.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MugenFG360 »</TD></TR><TR><TD CLASS="quote">+43 recommended for mf10's using aftermarket calipers such as endless / spoon</TD></TR></TABLE>
cool...thanks.
cool...thanks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spikey »</TD></TR><TR><TD CLASS="quote">you will need to use a spacer and probably longer studs
if using a +43 offset...i would need a spacer and longer studs?
</TD></TR></TABLE>if using a +43 offset...i would need a spacer and longer studs?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Saga »</TD></TR><TR><TD CLASS="quote">correct, sir.
what about the offset of +50 on an EK? will i have any problems?
</TD></TR></TABLE>what about the offset of +50 on an EK? will i have any problems?
damn those are nice!! how much are the endless calipers? are they 4 piston or 6 piston calipers?
</TD></TR></TABLE>damn those are nice!! how much are the endless calipers? are they 4 piston or 6 piston calipers?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Saga »</TD></TR><TR><TD CLASS="quote">With +50, you will need a thicker spacer.
Those are the 4pot.</TD></TR></TABLE>Correct only the 4 pot. The 6 pot requires at least 17 inch wheels.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Supertwinz »</TD></TR><TR><TD CLASS="quote">Correct only the 4 pot. The 6 pot requires at least 17 inch wheels.</TD></TR></TABLE>
really? i remember seeing this turbo r in a importtuner (this was a while back) who was using some zeal 6 pot calipers on 16 inch mf-10's. the article said he was using spacers though.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ryu12341 »</TD></TR><TR><TD CLASS="quote">
really? i remember seeing this turbo r in a importtuner (this was a while back) who was using some zeal 6 pot calipers on 16 inch mf-10's. the article said he was using spacers though.</TD></TR></TABLE>I hate to prove you wrong buddy:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egcivicturbo »</TD></TR><TR><TD CLASS="quote">i have 15's on my dc with endless front rotors...</TD></TR></TABLE>
what rims? offset? width?
i called endless and they said that on an ITR, they used the mugen mf10's with a +43 offset w/ a 5mm spacer. should i just rule out buying the +50 offset and running a 10mm spacer (by looking at that niice bronze mugen ITR w/ mf10's and endless calipers, it looks like he is running a +50 offset and it mentions that he is using a 10mm spacer.) i am getting diff. responses from everybody...so which one would be the best way to go?
