need help wiring my hks type one turbo timer
my problem is this i have everything wired up fine except for the rpm wire. hks says i need a 5 volt digital signal. i was thinking about wiring it to the same wire that comes out of the msd for my tach but then found out that it is a 12 volt analog. my question is this are there any other ways to wire it other than buying the level converter through hks for $60. would it work if i wired it up to the alternator?
Did you try the forced induction forum? I would help if I knew but you know I don't know, why don't you try asking Jon?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kris »</TD></TR><TR><TD CLASS="quote">Did you try the forced induction forum? I would help if I knew but you know I don't know, why don't you try asking Jon?</TD></TR></TABLE>
already did with no luck
DIRTYsouthBB6
Apr 19, 2006 11:11 AM
