Ignition Timing Q
Old May 2, 2003 | 04:19 PM
teg92's Avatar
Default Ignition Timing Q
When starting the new 12.5:1 motor I built I backed off the distrubutor to retard the timing fully. The motor so far has had about 10 minutes of running time but I just wanted to be safe for the initial startup, and now since I know everything is okay I would like to properly setup my timing for the break-in. I am sure that it is probably retarded so much that it could cause my idle to be slightly rough and a little sluggish, but I just wanted to confirm that backing off the dist all the way could cause a noticable effect at idle.
Old May 2, 2003 | 04:38 PM
tek_civic's Avatar
Default Re: Ignition Timing Q (teg92)
i believe it will, i was told this but i can't remember by who, so i might be wrong. let us know how it preforms, sounds pretty mean!
gooblinn258
Dec 12, 2013 06:21 PM
SOHCMAN
May 31, 2005 03:10 PM
handa
Apr 11, 2005 10:36 AM
RTW DC2R
Mar 9, 2004 09:09 AM
P1mpSlap
Jul 29, 2003 10:17 PM
