Does a lighter valvetrain=more hp?
Am I going to gain hp from having a lighter springs,retainers, and valves, or is it just going to be easier on the motor at high rpms? Gimme all you guys got on this... I searched and didn't find anything too specific.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Waachback »</TD></TR><TR><TD CLASS="quote">yea</TD></TR></TABLE>
Explain please.
Explain please.
Hmmmm what makes you think this??? A lighter valvetrain can allow you to rev higher which creates more power as HP=torgue*rpm/5252 however your cams powerband better go as high as you are reving or it is pointless. Putting a lighter valvetrain alone with do jack.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DeafNgari »</TD></TR><TR><TD CLASS="quote">
Hmmmm what makes you think this??? A lighter valvetrain can allow you to rev higher which creates more power as HP=torgue*rpm/5252 however your cams powerband better go as high as you are reving or it is pointless. Putting a lighter valvetrain alone with do jack.</TD></TR></TABLE>
you beat me to it, but to add some info, the lighter the valvetrain the more an engine can rev and the faster it revs.
But i don't think it'll increase HP or TQ, just MHO. In case it increases HP or TQ it'll be very low amount of power. i'm not sure on that.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VtecDA9 »</TD></TR><TR><TD CLASS="quote">Am I going to gain hp from having a lighter springs,retainers, and valves, or is it just going to be easier on the motor at high rpms? Gimme all you guys got on this... I searched and didn't find anything too specific.</TD></TR></TABLE>
like the others say, lightened v.train will not make power...but.... a lightened v.train is like training wheels for other components in your head, mainly the camshafts...allowing you to safely rev higher, as your making power beyone a stock redline, which your cams are in direct control of, and if your ecu has been reprogrammed with a higher redline.
In other words, its almost like having a lightened flywheel for your valvetrain, but the weight savings isn't as noticeable as a lightened f.wheel is. Valvetrain components are not too heavy to begin with. Its just a safer alternative for your internal head components if you do a lot of high reving.
advantages, benefits, gain, hondatech, horsepower, hp, increase, lightened, lighter, power, train, valve, valvetrain
