yo yo yo , obd-0 to 1 problems.....need help!!!!!
Old May 2, 2003 | 01:07 PM
RAMBO's Avatar
Default yo yo yo , obd-0 to 1 problems.....need help!!!!!
I am uncertain if i am able to use a 90 integra distributor with my obd1 comp.
The distributor has clear plugs as does the factory 89si harness which i have been told to use. I have a b18b1 LS integ motor with a Gude head and Gude reprogrammed ecu and will be running a 12.5:1 compression ratio. I have ordered my ecu conversion harness and was recently told that i need to use a 94-
distributor for the ecu to be compatible....which makes absolutly perfect sence.
But if i get an obd 1 distributor the engine harness will not plug up (clear plugs as apposed to the obd1 plugs) ahhhh problems!!!! maybe ill run the stock si ecu for now if **** doesnt work out but im affraid it might !@%# up **** being that the Gude ecu has a completely diff fuel curve.
So my question again is.....can i make the 90 integ dist work with the obd1 comp.....please help , anyone?
Old May 2, 2003 | 01:45 PM
Doodoo's Avatar
Default Re: yo yo yo , obd-0 to 1 problems.....need help!!!!! (RAMBO)
No you can't. You have to re-pin a 94-95 distributor with the 90-91 connector to match the colors on your engine harness. All the colors should match. There are 2 White wires on the OBD1 distributor. If your car doesn't start then switch them around. That usually solves that problem.
Old May 2, 2003 | 02:13 PM
Urban Business
Guest
Posts: n/a
Default Re: yo yo yo , obd-0 to 1 problems.....need help!!!!! (Doodoo)
yeah you can swap connectors on the dizzy or on the harness side. doesnt matter as long as you get the **** to fit. match up the colors. it shall work
Old May 4, 2003 | 06:48 AM
RAMBO's Avatar
Default Re: yo yo yo , obd-0 to 1 problems.....need help!!!!! (limoZeen)
thankyou for you assistance.......soon the "Beast Car" c. will be unleashed.
THANKYOU !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
becauseracecar8
Feb 24, 2016 07:10 PM
fin781
Jan 19, 2007 09:16 PM
89hatcher
Jun 5, 2006 02:01 AM
si0385.
Jan 1, 2006 10:00 AM
Cjsls
Feb 10, 2004 06:33 PM
